how to wire a choke in a previously EFI car?
Re: how to wire a choke in a previously EFI car?
If you aren't worried about the light on the dash, just run any switched power source to the power lead on your choke.
Not sure how to wire it so that the light in the dash functions properly, so if anyone else knows, please share.
- Justin
- Justin
so just anu 12v power source with a switch? turn it on when i start and turn it off.....once it warms up? just once it fires?
i dont want alot of switches around my car, i allready have a retarded fan switch on my dash lol
Sorry....by switched power source, I meant ignition switched power (power only when the key is in the start or run position). The choke will close it self once the engine no longer needs it.
- Justin
- Justin
is the choke on only to start the car or untill its warm? cuz to keep my car running i gotta hold it around 2k rpm untill it warms up (like 2 minutes)
the ignition may be a problem, cuz i originaly had my E fan on the ignition but had to take it off because it was causing weird problems, like i would kill the car but the engine would still run for like 10 more seconds, and it would blow fuses left and right
fpete1992
Dec 11, 2014 03:51 PM
