Brake warning light just came on...What could it be?
Old Sep 6, 2004 | 08:41 PM
chamorro's Avatar
theres no leaks or anything.
Old Sep 6, 2004 | 10:42 PM
Stephen 87 IROC's Avatar
Re: Brake warning light just came on...What could it be?
Any fluid in the master cylinder? The light comes on when the pressure goes low on one side of the combination valve. This forces the warning switch over to one side creating a contact to ground. If you're not losing fluid anywhere. check the wiring to see if it's grounded out anywhere.
Old Sep 6, 2004 | 10:52 PM
aklim's Avatar
Could be a bad sensor in the master cylinder area
Old Sep 7, 2004 | 04:31 PM
chamorro's Avatar
How do i fix it and is it an easy fix? also, my brakes knock sometimes. i think its only the front right that knocks, what could that be? could it have anything to do with the light?
Old Sep 7, 2004 | 04:34 PM
Rice Killer87's Avatar
ive never heard of a brake knock before,have u ever pulled the tires off and checked the brakes/pads and such?
Old Sep 7, 2004 | 05:18 PM
chamorro's Avatar
Well im not 100% sure that its the brake thats knocking. im also thinking it could be the shocks. can it be the shocks?
jj_burchiel
Mar 21, 2015 12:51 AM
Jlo
Feb 3, 2015 09:41 PM
squarehead
Jan 15, 2015 07:02 PM
Scottylt1
Jan 8, 2015 02:48 PM
Scottylt1
Dec 4, 2014 12:31 PM
