305 Vortec vs 350 Vortec Heads
Old Sep 21, 2004 | 10:06 PM
Alien's Avatar
All my seaching has been confirmed here that 305 Vortecs will not flow as well as 350 Vortecs and most people suggest just to use a pair of 350 vortecs for a 350 block. My question is, is there anything that can be done to a pair of 305's that will equal if not better the 350's?
I have a 86 Camaro (primarily used for autocrossing, less than 5400 rpm) with a 350 +.020 4-valve relief stock replacement pistions, XR258HR Hyd Roller Comp cam (258/264 adv. dur and .480/.487 lift), shorty headers, Edelbrock Performer intake with a Road Demon Jr. 625 carb. CR unknown. The heads are currently 350 tbi truck heads and either 305 vortecs or 350 vortecs would be an improvement. I was given (free) a pair of 305 Vortec heads cast #12558059 1.84/1.5 valves (64cc?). Obviously I'ld have to get a new intake to use these and to swap out the springs for the ones set up for the comp cam. I am the counterman at a machine shop, and my head man can install 1.94 valves and smooth out the exhaust ports for better flow. Unfortunatly we don't have a flow bench as we don't do much performance work. What else should be done (if anything) to help the 305 heads breathe, or should I just buy 350 vortecs and start from there?
Gary R.
Old Sep 22, 2004 | 11:46 AM
Ucantcme57's Avatar
Re: 305 Vortec vs 350 Vortec Heads
It only took a min and I think I have the link that you would need..
Also from what I believe is a very reputable company..
http://www.carcraft.com/techarticles...rt/index1.html
http://www.carcraft.com/techarticles...rt/index2.html
http://chevyhiperformance.com/howto/97458/
http://chevyhiperformance.com/howto/97458/index1.html
http://chevyhiperformance.com/howto/97458/index2.html
Hope all of this helps...
Old Nov 26, 2004 | 09:43 AM
ZPI28's Avatar
Looks like port work on the exhaust is where its at. Thanks for the links..
Steven
F'n1996Z28SS
Aug 23, 2023 11:19 PM
dawg irocz
Feb 10, 2015 10:33 AM
Chris Anderson
Jan 27, 2015 08:30 AM
InfernalVortex
Jan 17, 2015 09:35 AM
markaubuchon
Jan 14, 2015 01:48 AM
