fuel rails leaking
Old Sep 7, 2004 | 03:06 PM
nightrider's Avatar
fuel rails leaking
i've been having trouble with the fuel return line, and to get it unclogged i had to dis-assembled the fuel rails. i bought the seal kit from auto zone, re-assembled, and put back in the engine. when ever it was under pressure, it would leak. i took them out, cleaned the fittings and bought a new seal kit. this time it leaked at soon as i put it in the car. i let it set over night and it seemed to stop leaking. this only lasted for a week and they're back to leaking. what do you guys suggest i do? car's been out or running rich all summer.
*it's leaking between the passenger side rail and the fpr
Old Sep 7, 2004 | 04:30 PM
Rice Killer87's Avatar
Re: fuel rails leaking
is there a pin hole in the rail or is it coming from a fitting?
when u say seal kit,that means o-rings and stuff right?
check around the FPR,i know theres a thin rubber gasket around it as well
im not sure man,hope that helps
Old Sep 7, 2004 | 10:34 PM
FruityOne's Avatar
When you are installing the ruel rail did you put any vaseline or lubricant on the o-rings? Sometimes you can tear or damage them when you pop the injectors in place.
Old Sep 8, 2004 | 07:56 PM
nightrider's Avatar
there is no pin hole, it's coming from the fitting. i didn't use any lube on the o-rings. and yes, when i say seal kit i mean the o-rings. this is really getting frustrating, we finally find the problem (clogged return line), but putting it back together poses all the problems. Thanks for any help.
HectorM52
Jul 30, 2017 11:46 AM
dfarr67
Apr 10, 2015 07:44 PM
4586
Feb 13, 2015 09:16 AM
birdblack
Dec 30, 2014 06:59 PM
Jul 4, 2005 05:00 PM
