28in tall tire 10in wide rim clearance????
Old Oct 2, 2004 | 04:19 PM
1984camaroz28's Avatar
WIll i need to clearance to fir this combo. This is the rite tire/rims combo i need to get my car to hook
Old Oct 3, 2004 | 07:29 PM
Re: 28in tall tire 10in wide rim clearance????
ttt
Old Oct 4, 2004 | 12:47 AM
kandied91z's Avatar
depends on your offset wheel. what is the offset backspacing? the width of the tire too?
not enough info. i had 195/35/18 on a 10 with 6.75 nad it was perfect. if your going to run taller i'd suggest stepping out futher at least an inch or so on the bs.
Old Oct 4, 2004 | 06:35 AM
aziroc's Avatar
i was going 2 go with a 28 in tall tire, but went with a 26 (ET Streets 26x11.5x15) by backspacing is whatever the stock size is, and i BARELY get rubbing on the outside.. but ever since i rolled the fender it was fine... but if i went with a 28" tire, it would b shreded.
Old Oct 4, 2004 | 01:01 PM
Weld Draglite 15" x 10" rear rims (5.5" back spacing with a M/T ET Drags 28 "W" with tubes and rim screws is what the spohn car is runing. Im looking to run the exact same setup looking for what i need to do in order to fit this combo in there
Old Oct 4, 2004 | 02:50 PM
kandied91z's Avatar
why not email him then....or call. i'm sure he'd help you with it.
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
KillerTA
Wheels and Tires
May 31, 2015 12:20 PM
LD Kirk
Apr 30, 2015 08:54 AM
vandelay101
Sep 7, 2002 12:03 PM
