Swapping Motors
Old Oct 3, 2004 | 03:06 PM
Yossarian14's Avatar
Swapping Motors
If you take a 305 out and stick a 350 in a 1986 Camaro, how much work will it be? Will the 350 work with the motor mounts, transmission, etc?
Old Oct 3, 2004 | 03:30 PM
Re: Swapping Motors
Its a 305 with a carb by the way, no TPI.
Old Oct 4, 2004 | 01:00 PM
Re: Swapping Motors
Should I rip the emissions controls out then since none of that junk with work with the 350 Im putting in probably?
Old Oct 4, 2004 | 03:51 PM
zrs's Avatar
zrs
Re: Swapping Motors
Depending if your state has smog checks, I would keep it in. I just installed a 350 in an 86 Z-28 with 4bbl. I am assuming your 86 is the same. Everything will bolt up including your accessories. If you have the $, I would get some headers since you are installing another engine and this would be the best time to install it. As far as sensors goes, you will need to replace the knock sensors and I believe another sensor as well but I don’t remember the name. Also go with an open air element to go with your setup.
Old Oct 4, 2004 | 04:43 PM
Rice Killer87's Avatar
Re: Swapping Motors
everything will swap right over including motor mounts as long as the heads are the same style...either 86 and older or 87 and newer.
not sure about zrs,but when i swapped a 305 TPI to a 350 TPI i ran the car w/ the 305 computer and used all the sensors off of the 305,they swap right over.
when u change motors,theres a metal pipe that takes air from the air pump on the pass. side to the pipes on the exhaust manifold on the driver side that u need to leave off when u put the motor back in. it makes gettin to the bellhousing bolts hell as well the stud on the back of the pass. side head where there are 4 ground wires/grounding strap. i also put in a set of Hedman headers while i changed motors (w/o the air tubes) and i just ran a 5/8 heater hose from the air pump to the metal tube that runs down the back of the motor and goes to the cat,so it looks like its working...but really its doing nothing.
Old Oct 4, 2004 | 06:12 PM
zrs's Avatar
zrs
Re: Swapping Motors
Rice Killer87,
I am in the process of assembling my 350 with vortec heads (machined for high lift, screw in stud and 1.6 rockers) with the LT4 Hot Cam. I see you are using a 600 Edel carb. Are you planning on using a higher cfm carb? I am still debating on what type of induction setup I will be going with. Any suggestion?
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
transam_388
Mar 15, 2015 11:53 AM
jj_burchiel
Mar 5, 2015 07:05 AM
89 iroc zl1
Jan 14, 2015 02:18 AM
