Water Necks universal?
Old Sep 21, 2004 | 02:14 PM
85_305's Avatar
Ok.. say I were to buy a intake manifold off of ebay. Lets say, this manifold doesn't come with a water neck. Are all water neck's universal? Does it matter if it is a 90-degree, or 20-degree, or what?
Thanx all,
Matt
Old Sep 21, 2004 | 02:22 PM
aklim's Avatar
Re: Water Necks universal?
EFI ones are different and are smaller than the old style ones. You need to know the application first
Old Sep 21, 2004 | 02:47 PM
85_305's Avatar
Hey aklim... nice to talk to you again! Well, I know it's not EFI.. but will any carb'd manifold take any carb'd water neck? Does year matter? I looked around ebay for water necks.. none say years they fit though.
Old Sep 21, 2004 | 04:33 PM
Rice Killer87's Avatar
yes,carb'd thermostat housings are universal...atleast on Chevy's
Old Sep 21, 2004 | 04:49 PM
85_305's Avatar
The water neck is aka Thermostat housing? So is that where the thermostat for the cluster gauge is?
Old Sep 22, 2004 | 07:34 AM
raul.garcia's Avatar
The thermostat is mechanical; it is calibrated to open and close to control engine temperature around 195°F - 220°F.
The engine temperature sending unit for the cluster temp gauge is located between and below the #1 & 3 spark plug holes. Single wire usually green.
Old Sep 22, 2004 | 09:09 AM
Tru2Chevy's Avatar
Really?
I thought they were usually white.....
- Justin
Old Sep 22, 2004 | 04:59 PM
aklim's Avatar
Originally Posted by Tru2Chevy
Really?
- Justin
So far it has been green for me. However when someone replaces the wire because it got loose and hit the exhaust manifold and melted, it is white because that is what color comes from the GM dealership or parts house. Replace a TPS sensor harness and see 3 white wires.
Old Sep 22, 2004 | 08:17 PM
85_305's Avatar
So is the thermostat housing also known as the water neck.. or are they different?
Old Sep 22, 2004 | 09:09 PM
aklim's Avatar
AFAIK, yes.
Old Sep 24, 2004 | 09:20 PM
85_305's Avatar
Ok, koolness
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
colts0455
Sep 27, 2015 01:07 PM
Pwilson59
Sep 3, 2015 08:47 PM
