Fuel Injectors
Old Sep 9, 2004 | 02:55 PM
ELLISESSIE's Avatar
Fuel Injectors
I had a diagnostics done, and they related that I need 4 new fuel injectors(91 cvevy z28 convertable). I am going to try an change them myself, but how will I know which 4 needs to be shanged?
RC
INDY
Old Sep 9, 2004 | 03:37 PM
Scrote's Avatar
Re: Fuel Injectors
If you have access to a DVOM you could ohm them out...should be right around 12.5 ohms for a stock Rochestor or Bosch unit. If they all ohm out ok, try pulling the plugs and taking a look at there conditon, if 4 are running lean, or on the other hand 4 are compleatly washed clean then you have your culprit.
Take care,
Erik
Old Sep 9, 2004 | 04:40 PM
ELLISESSIE's Avatar
Re: Fuel Injectors
Thanks Eric, will look at the plugs tonight.
Old Sep 9, 2004 | 05:01 PM
Scrote's Avatar
Re: Fuel Injectors
No problem
AdsoYo
May 2, 2018 03:21 AM
daves91z28
May 12, 2016 06:19 AM
MyfateZ28
Jun 19, 2015 03:42 AM
QuickSilver02
Apr 7, 2015 11:12 AM
Jul 4, 2005 05:00 PM
