Need Help Single Or Dual Plane Intake
Old Oct 14, 2004 | 07:23 PM
86z28nos's Avatar
Angry Need Help Single Or Dual Plane Intake
Ok I Have A 350 Bored 60 Over With Factory Pistons The Cam Is A Zz4 Cam 208 221 Duration At .050 And 112 Lobe Separation 506 544 Max Lift With 1.6 Motown Heads With 2.05 Int And 1.60 Exh And I Have A Weiand X Celerator Single Plane Intake And A 750 Edelbrock Carb And This Is Going To Be A Daily Driver And Weekend Race So Should I Use The Single Are Should I Go Get A Good Dual Plane
Old Oct 14, 2004 | 07:52 PM
five7kid's Avatar
Edelbrock RPM or Weiand Stealth intake.
I'd also say a Holley or Demon double pumper as well.
Old Oct 14, 2004 | 08:00 PM
fbodyfreak's Avatar
Re: Need Help Single Or Dual Plane Intake
The single plain will give you more low end torque.
Old Oct 14, 2004 | 08:17 PM
Stekman's Avatar
No it won't.
Single plane = high RPM hp
dual plane = low(er) end torque
Old Oct 14, 2004 | 08:37 PM
fbodyfreak's Avatar
your right stekman, sorry for the wrong info, its been a while since ive fooled with carburated engines.
Old Oct 14, 2004 | 09:03 PM
TheGreatJ's Avatar
Since she's a daily driver I'll say go with the dual plane. A single plane will move the powerband up so high that it won't be usable on the street, and IMHO that cam doesn't have enough duration to warrant it.
As a side note, I hope you mean factory STYLE pistons....using stock size pistons in a block bored .060 over is just asking for gouged cylinders.
Old Oct 14, 2004 | 10:03 PM
86z28nos's Avatar
yes thats what i ment thay are factory STYLE pistons the pistons are 60 over thanks
Old Oct 15, 2004 | 01:31 AM
trwchevy's Avatar
also theres some spacers you could look into...ive heard they help a little..
Old Oct 15, 2004 | 06:01 AM
jzajac1's Avatar
I recently purchased a Edelbrock RPM Air-Gap dual plane & it has the best of both single & dual plane combined. It was worth every penny I paid for it ($226). It maintains your low end power/torque & also offers high end breathing and rpm's.
R@mpage
Apr 20, 2015 10:02 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Elcojoe
Nov 17, 2014 10:27 PM
