Bouncing Oil Gauge
Old Oct 10, 2004 | 09:25 PM
Bruticus's Avatar
Bouncing Oil Gauge
My oil Gauge bounces from time to time any ideas what can be causing this.
Old Oct 11, 2004 | 06:51 AM
blue69camaro383's Avatar
Re: Bouncing Oil Gauge
check the sender and the connection at the sender
Old Oct 11, 2004 | 02:47 PM
Bruticus's Avatar
Where would that be located at sorry im new to F Bodies.
Old Oct 11, 2004 | 03:16 PM
Blackbird89's Avatar
It will either be behind the Intake manifold, or right above your oil filter.It will look similar to an o2 sensor.Mine was having the same problems.Put a new oil sending unit in, and haven't had any problems.Easiest way for me to get it off was cut it close to the base, get a swivel head ratchet, and a 30mm socket and take it off.The sockets they make for them wouldn't go around the new/old one.
Hope this helps.
Old Oct 11, 2004 | 03:27 PM
Yossarian14's Avatar
I cant remember what any of the parts are called but if you go to like thirdgen.com and *** they mention that problem and it says that you need to oil something that connect to the guage since its a mech.
Old Oct 11, 2004 | 08:48 PM
Yea, it is a mechanical oil sending unit.You will need to buy an oil sending unit.any parts store should have one in stock.I would try and get a Delco/Delphi one if it was me.
Red Hawk 94
Mar 18, 2019 04:03 PM
nosliw
Apr 27, 2015 04:01 PM
surreybrad
Apr 22, 2015 06:40 AM
99TransAmWS6
Feb 12, 2015 07:23 PM
jj71787
Jan 31, 2015 10:20 PM
