First mods for TPI??
Old Sep 13, 2004 | 10:38 PM
kbog54's Avatar
Hi, I'm wondering which mods i should start out with on my new formula, current mods are in the sig-long tube headers are already on the way, but i'm not too familiar with the TPI's so i need some advice on where i should put my money to get the most gains.
I was thinking about ordering a cam, one that works with my chip- would this be a good idea?
Old Sep 14, 2004 | 12:24 AM
Kevin91Z's Avatar
3rd Gen Tech Moderator
Re: First mods for TPI??
What about the rest of your exhaust?
Check out the tech articles on www.thirdgen.org . There are lots of suggested mods there. If it were up to me, I would wait until you rebuild the engine, then add in the good things like a cam and heads. For now, concentrate on little things like the intake manifold and plenum.
Old Sep 14, 2004 | 12:19 PM
Tru2Chevy's Avatar
Pull the hypertech chip and get one that is custom made for your motor.....plug and play programs are never as good as a custom one.
- Justin
Old Sep 14, 2004 | 12:28 PM
Dyosis's Avatar
Headers are a good start. There are a few cheap mods like throttlebody bypass and porting you plenum. Gears is a must (3.2x or 3.4x for TPI). You might want to look into getting a Holley Stealthram, they seem to be the best bang for the buck for an intake. You will have to get a chip burnt if you do get one though.
Go checkout thirdgen.org like Kevin said, you will find all of the info and more over there.
Old Sep 16, 2004 | 12:16 AM
WhiteKid's Avatar
TPI's are torque monsters. Only problem with them is the top end. The TPI intake plenum and runners restrict to much air for top end. Ive taken a 86 custom Turbo Supra (13.9 1/4 mile) off the line but he took me right after cause i had nothing above 4500rpms. Do the stealthram. Best bang for $600. I siamesed my runners but in my opinion all that time i put into it i should have bought the stealth. Well I am this winter Good luck
G-BODYT56
Jan 14, 2022 11:14 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
DelSoto
Sep 19, 2015 05:31 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
