89 fbird 305, need to remove key security
Old Oct 13, 2004 | 10:47 PM
YARDofSTUF's Avatar
Question 89 fbird 305, need to remove key security
Ok so i'm slowly looking to start my baby thats been dormant way too long, but I cant find the key.
I've heard that this key chip security thing can be removed, but I need a list of the crap I have to take out, I assume someone has done this here. Any help would be great.
Old Oct 14, 2004 | 01:17 PM
YARDofSTUF's Avatar
Re: 89 fbird 305, need to remove key security
Am I in the wrong forum?
Old Oct 14, 2004 | 02:26 PM
WS Sick's Avatar
To do it properly you have to have it programmed out of the prom, then bypass the vats module. For a complete todo list on it goto this site..
http://thirdgen.org/
Old Oct 14, 2004 | 02:29 PM
YARDofSTUF's Avatar
To bypass the system you ll need to buy a resistor with a value matching that of your keys chip at any local electronics store.
Hmmm, what if I dont know the value?
Cool site, bookmarked!
Old Oct 14, 2004 | 03:42 PM
Scrote's Avatar
You need the key to check the ohms accross the resistor in the key...but you dont have the key so I guess the only thing left to do is crush the car...
Old Oct 14, 2004 | 03:45 PM
WS Sick's Avatar
I know that GM actually used a finite number of resistance chips. If I remember right its well under 20. But If you get it removed from the computer a simple bypass will take care of the module. If the computer isnt looking for the signal no vats signal is needed.
Old Oct 14, 2004 | 04:36 PM
crash4cyl's Avatar
to be truthfull they only used like 9 different keys...It get expensive to stock 20 different keys that cost them $15 a peice....I used to work for a GM dealership in parts....especially when you need to stock 20 a peice just in case... Too bad the car is over 10 years old....GM stores VIN's for 10 years and you could have taken the VIN to them and had them cut you a new key. Your best bet is to get a new lock cylinder with a key and then you don't have to worry about it. Either your Local Chevy Dealer or auto store should supply wou with what you need.
Chris
Old Oct 15, 2004 | 11:57 AM
trwchevy's Avatar
or you could do what i did...lol my buddies 88 camaro key works in my 86...but mine doesnt work in his...good luck
Old Oct 16, 2004 | 03:15 AM
YARDofSTUF's Avatar
Chris
Pricey or not too bad?
Old Oct 16, 2004 | 07:48 PM
irocznformula's Avatar
is it possible just to swap the ign switch/key or column to fix the problem? just wondering cause i have the column, keys and the little yellow box that i think is the module from my 89 formula that i scrapped.
Old Oct 16, 2004 | 10:18 PM
firebirdjosh's Avatar
I wonder how accurate the resistance has to be? In the right case I bet using a potentiometer and turning it slightly every time and cranking it to see what happens may be a slow yet easy process.
Old Oct 17, 2004 | 01:37 PM
Zepher's Avatar
VATS key and Lock Cylinder from Claasic Industries is about $40.
To bypass VATS in the prom, all you do is turn it off in the prom, and that is it, but you will need an adaptor and blank prom if your ECM uses a memcal (you can cut off the stock prom from the memcal and unsolder all the leads and then put a socket in there also, I did that before the adaptors were available) , TBI cars don't need an adaptor since thier prom plugs right into the ECM.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
moparman
Mar 5, 2015 08:47 AM
Oncomingstorm22
Jan 22, 2015 07:15 PM
markaubuchon
Jan 14, 2015 01:48 AM
