oil cooler snap ring and gasket?
Old Sep 24, 2004 | 09:11 PM
Osmosis's Avatar
I am rebuild my engine. The factory oil cooler was sitting in a box. A snap ring popped off the cooler. I could have swore that it came off the top of the cooler. I inspected the shaft where the oil filter attaches to and it looks like it has a grove to hold the snap ring..but I could have swore it came off the top of the cooler??? Also, the top part of the oil cooler has a perfectly flat surface that mates with the block. Is there a gasket for that part of the cooler? IF so, is it a paper gasket? OR a thick rubber piece?
HELP!!!
Old Sep 30, 2004 | 07:47 AM
transambill's Avatar
Re: oil cooler snap ring and gasket?
Not sure on the snap ring,but theres a thick flat rubber O ring gasket between the cooler and the block.
Old Oct 1, 2004 | 06:02 PM
92rslt1's Avatar
you dont realy need your oil cooler. it doesnt do that much. im assuming this is a tpi v8?? you can get your filter to screw directly into the bolck.
Old Oct 1, 2004 | 08:12 PM
aklim's Avatar
You could get away without an oil cooler but you would have to route your hoses and run with hotter oil.
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
blkWidow
Apr 20, 2015 09:27 AM
97 RedSS
Jun 10, 2003 07:58 PM
GA93FORMULA
Jul 24, 2002 11:38 PM
