Converting my 85' Chevy truck to TPI.
Old Sep 21, 2004 | 04:42 PM
TravisA's Avatar
I'm toying with the idea of conveting my 85' pickup to FI. How do you think a stock TPI intake setup would perform on a Daily driven truck? It will also be used occasionally for towing?
Also would this be an easy swap, if i have the complete intake system plus the computer from a TPI car?
Thanks for any help
Travis
Old Sep 21, 2004 | 04:44 PM
Rice Killer87's Avatar
Re: Converting my 85' Chevy truck to TPI.
the TPI makes great torque at low RPM's so its a pretty good setup on a truck.
if u have the intake, computer, and harness from the donor car you are set,or Painless makes a harness for it as well to swap the TPI into something other than a Camaro/Firebird.
good luck w/ the swap.
Old Sep 21, 2004 | 04:46 PM
TravisA's Avatar
Hey thanks for the quick response!
What about the fuel pump? Did the TPI car use an electric pump or a mechanical?
Thanks again
Old Sep 21, 2004 | 08:13 PM
TravisA's Avatar
Never mind i found the answer to my question.....should have been obvious to me...fuel injection systems need a little higher fuel pressure than carb setups doh ...lol
Old Sep 21, 2004 | 08:29 PM
TravisA's Avatar
Also will all year TPI intakes (85-92) bolt up to my 85' block?
Old Sep 22, 2004 | 06:30 AM
thezisking's Avatar
I don't think the intake will bolt to your heads. I'm pretty sure that the TPI setup used different angled heads. Maybe someone else can confirm this?.?.
Old Sep 22, 2004 | 07:18 AM
raul.garcia's Avatar
Vortec & fast burn won't because bolts are vertical, and the head intake port is a 1/4" longer.
Old Sep 22, 2004 | 08:57 AM
Zepher's Avatar
All years of TPI can bolt to your heads, 85-86 will bolt on with no modification. 87-92 will require you to elongate the 4 center holes so the bolt can get a straight shot at the heads.
Old Sep 22, 2004 | 10:14 AM
Ucantcme57's Avatar
unless it is a tbi motor your heads will work, TBI are all angled, I believe or is it the TPI heads are all angled.. ? TPI would be great for a truck.. I wish I would have put it on my 88 TBI chevy...
Old Sep 22, 2004 | 11:04 AM
Zepher's Avatar
From my understanding, 87+ sbc are angle heads. Vette may be different since I recall something about thier aluminum heads using the 86 and earlier intake pattern.
Old Sep 22, 2004 | 01:08 PM
TravisA's Avatar
Would it be better to avoid an 85' TPI computer? What year would be the best this conversion?
Old Sep 22, 2004 | 05:31 PM
Zepher's Avatar
avoid 85 ECM like the plague. I personally prefer the 90-92 Speed Density system since I don't really care for the MAF.
85 has the lousy ECM and expensive MAF Burnoff Relay
86-88 has the Cold Start Injector and MAF system (late 88's have VATS according to a book I read).
89 has no Cold Start Injector and is MAF and has VATS
90-92 is Speed Density and has VATS.
Old Sep 22, 2004 | 05:51 PM
TravisA's Avatar
Thanks for the help.
It seems like a fairly straight swap. Could I use an inline pump or would I need an intank pump? I'm assuming I would have to rig up a return line also.
Old Sep 22, 2004 | 07:09 PM
Zepher's Avatar
inline pump is fine,that is what I ran when I did my TPI swap on my 86 T/A back in 2001.
Return line should be no problem on a truck since you have plenty of space to work under. 5/16 is the size of our return lines.
Old Sep 22, 2004 | 07:38 PM
TravisA's Avatar
So did the 86' have a mechanical pump before? I guess what I need to know is can i use the existing fuel line coming from the tank to pull the fuel with the inline pump?
Thanks for all the help!
