Difference in Impala/F-body/Vette LT1?
Old Oct 13, 2004 | 12:06 AM
Jacobs454's Avatar
I know the Impala packs 260HP, F-body 275HP (w/o SS), and Vette 300HP, but other than that are they pretty much the same dimensions? I'm still (yes, STILL) in the hunt for a LT1 and cam across a wrecked Caprice Sherrif's Dept car for dirt cheap. It only has 85K on the clock and the motor/driveline is good. Is this gonna be any easier/harder to swap than a F-body or Vette LT1? Any info would be gretaly appreciated! Preesh
Old Oct 13, 2004 | 12:31 AM
trwchevy's Avatar
Re: Difference in Impala/F-body/Vette LT1?
im not sure....but i would guess they would be pretty much the same...aside from cams...fuel injectors...alot probably from the computer...but try posting a message in the LT1 category on the main message boards...they will tell you for sure...let me know if you find an x-tra one...lol
Old Oct 13, 2004 | 01:07 AM
FruityOne's Avatar
F-bodies and Vettes recieved aluminum heads. Impala's and Caprice LT1's had iron heads.
The Vettes got better exhaust manifolds than the F-bodies or Caprice/Impala LT1 cars.
The iron LT1 heads are supposed to flow just as well as the Aluminum versions from what I've read on these boards.
Old Oct 13, 2004 | 07:27 AM
fbodyfreak's Avatar
wow I have an f body with an lt1 and it has iron heads not aluminum, it wasnt till 96 or 97 when they made the switch to aluminum. Also watch, the caprice also had a 4.3 v8, that looks just like the lt1, just has smaller cylinder bores.
Old Oct 13, 2004 | 08:31 AM
iroc2000lt1's Avatar
Hey I'm new
Also the Vett LT1 its a 4 bolt main and the F-body, Impala's and Caprice LT1's are 2 bolt main.
Old Oct 13, 2004 | 11:40 AM
FruityOne's Avatar
Thats true, i forgot to mention that stuff. I wasn't aware that LT1's didn't get aluminum heads till 96/97.
I did know about the baby LT1. Fun fun.
Old Oct 13, 2004 | 02:18 PM
Drakar's Avatar
your's must not be original
93-95 f-body got aluminum heads first design, poor flow
96-97 f-body got aluminum heads second design better flow
all 94-96 Impala/Roadmaster/Fleetwoods got iron heads (medium flow)
all 94-96 Caprice equipped with LT1 (NOT L99 or baby LT1) Iron heads
LT4 heads have the best flow.
all stock of course.
Old Oct 13, 2004 | 09:17 PM
Zepher's Avatar
Here is a good breakdown of the LT1/4
http://www.automotiverebuilder.com/ar/ar99928.htm
Old Oct 13, 2004 | 09:54 PM
fbodyfreak's Avatar
No Drakar my 93 LT1 engine is all original and it has cast iron heads, its never even had the valve covers off of it. And its in a Formula, you need to check your source, its wrong.
Old Oct 14, 2004 | 12:58 AM
Zepher's Avatar
If you bought the car new, then you can say he is wrong, or you can't tell the difference between the 2. I helped tear apart my friends 93 Formula and his (and the 10 other 93's I've seen) all had Aluminum heads.
Old Oct 14, 2004 | 05:22 AM
thezisking's Avatar
You can tell for sure by sticking a magnet to the cylinder head. If it sticks, It's Cast iron, if it doesn't, it's aluminum.
Old Oct 14, 2004 | 04:57 PM
My LT1 is a 93 out of a Vett and it has aluminum head.
DirtyDaveW
Dec 1, 2016 05:37 PM
InfernalVortex
Jan 17, 2015 09:35 AM
Jul 4, 2005 05:00 PM
1LEThumper
Jul 14, 2003 12:45 PM
