Headlight Flicker
Old Oct 8, 2004 | 08:22 PM
Irocvette355's Avatar
Headlight Flicker
When I turn my highbeams on, after about 30 seconds all of the lights begin to flicker.
It does it when im just sitting there or driving, so i kinda ruled out the loose wire theory.
Bad relay?
Help! I need high beams!
o BTW the low beams are fine
Old Oct 8, 2004 | 08:42 PM
87DJP2001's Avatar
Re: Headlight Flicker
Are you using a underdrive pulley for the alternator???
Old Oct 8, 2004 | 08:52 PM
angel71rs's Avatar
I had this happen on my 71. It was the dimmer switch. FWIW
Old Oct 9, 2004 | 04:58 PM
nope no under drive pulleys.
Replaced the dimmer switch a while ago.
Im stumped.
Old Oct 9, 2004 | 05:27 PM
IROC-T's Avatar
Pull and clean the terminals on the bulbs,and pull and clean the grounds at the lights,both front and rear this might help.
Greg88
Sep 20, 2015 07:14 PM
Henson071
Sep 18, 2015 04:01 PM
jackpawt883
Sep 10, 2015 08:53 PM
Aug 17, 2015 09:50 AM
Henson071
Aug 4, 2015 09:32 AM
