Speedometer Problem
Old Oct 6, 2004 | 11:36 PM
Chris9450's Avatar
Speedometer Problem
As some may know, I did the v6 v8 swap in my 87 camaro, and put a turbo 350 transmission in it. The other day, I was test driving it and my speedometer needle just drops and stops working. I suppose it's the speedometer cable, but does anyone know if the speedometers in 87s were electronic or mechanical, and if there was something that I needed to do moving from the TH700 to the Turbo 350 concerning the speedometer cable? That's the only thing I can think of...it's worked fine ever since I had the car. If it is the speedometer cable, any help would be appreciated on how to change that...running a cable through the dash and hooking a gauge up to it seems very annoying to say the least, so any help would be appreciated.
Old Oct 7, 2004 | 05:29 AM
thezisking's Avatar
Re: Speedometer Problem
In 87, the Camaro had a cable driven speedometer. They switched to electric in 90. The Firebird changed to it in 87.
Old Oct 9, 2004 | 11:12 PM
Chris9450's Avatar
I found the problem. The speedo cable didn't break, the spring clip holding the drive gear on the tranny tail broke and the gear moved. Simple
nosliw
Apr 27, 2015 04:01 PM
Jubjub
Mar 19, 2015 10:23 AM
mattstrike
Mar 12, 2015 10:12 PM
sdn1997rs
Dec 30, 2014 08:30 AM
Darth Xed
13
Jul 22, 2002 12:45 PM
