Can I do this? Will it work?
Old Sep 6, 2004 | 09:18 PM
TechCam97's Avatar
Question Can I do this? Will it work?
Ok, lets say that I have a 5.0 TPI from an F-Body that was complete, ready to throw in and start driving. Then, I also have a 350 with no intake that's an 87+ style block with heads and everything. Can I take the TPI stuff off of the 305 and stick it on the 350 and have a 350 TPI?
Old Sep 6, 2004 | 09:31 PM
sahlomonic's Avatar
Re: Can I do this? Will it work?
Most definately. I don't see why it wouldn't work, to tell you the truth. It should all bolt up the same, only difference being the internals. Please someone correct me if I'm wrong . . .
Old Sep 6, 2004 | 09:58 PM
91LT16SpdFormy's Avatar
What year is the 305? If its 87+ as he said, yes it will work great.You might want to change injectors as the TPI 350s had 21lbs and 305 had 19lbs depending on what your doin w/ it also.
Old Sep 6, 2004 | 10:00 PM
krazzycowgirl's Avatar
Dont you mean 24lbs? My 87 5.7 had stock 24lb injectors
Old Sep 6, 2004 | 10:02 PM
Are you sure? I could be wrong but I didnt think GM used 24lbs in F Bodys until the LT1.?
Old Sep 6, 2004 | 11:00 PM
aklim's Avatar
Actuallly I believe they are 22 pph they ran rich with 24 pph
Old Sep 6, 2004 | 11:14 PM
Nope the ones that came in my car were 24s & since nothing was really changed in the last 17yrs I assume they were stock.
My car now has 30s in it which will change once the new chip is done & will go back to 24s.
Old Sep 6, 2004 | 11:16 PM
nape's Avatar
No it didn't. 305s came with 19lb injectors, 350s came with 22lb injectors. If yours had 24lb'ers then they weren't stock.
Old Sep 7, 2004 | 12:24 AM
Why would everything else in my car be stock & not the injectors? I mean when I got the car 2yrs ago it even had the factory org Fuel filter in it which was changed a year after I got the car. I mean EVERYThing but the steering wheel was factory org.
Plus when I called to have my chip done by two diff. shops they said they were 24lbs & all the race guys around here who work on TPI engines say they are 24 lbs?
Old Sep 7, 2004 | 01:13 AM
aklim's Avatar
I have seen the EPROM codes and they are set at 22. When I put 24 in it one time without the EPROM changes, the car ran rich.
Old Sep 7, 2004 | 01:16 AM
aklim's Avatar
Possibly because they had a probmem and had to change it to 24. You do realize that because of the GM tag on it, you get to pay a premium. Just like a lot of Bosch components are the same as Mercedes Benz and even have the same part numbers. However, because it comes in the silver box with the 3 point star, you get to pay more. If I was the previous owner, I might have elected to change the injectors because the EPROM will adjust for it. Only reason I knew it ran richer was because my car is SD and it doesn't adjust as well and I could see it on the scan tool.
Old Sep 7, 2004 | 01:33 AM
sahlomonic's Avatar
Taken from Chevy High Performance online tech article:
"The TPI manifold was originally designed for 305ci engines with 19 lb/hr fuel injectors operating at 36 psi, and employs a long and narrow runner to enhance bottom and midrange torque. The 350ci TPI-equipped engines use the same intake as the 305ci with larger 22 lb/hr injectors at 43.5 psi . . ."
Old Sep 7, 2004 | 03:16 AM
Then would someone please tell all the Perfessionals in this area & across the country they are WRONG & total idoits.
Old Sep 7, 2004 | 11:37 AM
sahlomonic's Avatar
I don't think I would go as far as calling all the "Perfessionals" around the country "total idiots", but perhaps miscommunication got the best of some of us . . .
Old Sep 7, 2004 | 11:44 AM
RedIrocZ-28's Avatar
Gladly, they never ever came with 24# injectors. Ever. 1993+ cars had 24#'ers with the advent of the LT1. (Or 1992 for the Corvette. )
