Hypertech fan switch
Old Sep 9, 2004 | 11:12 AM
shwine617's Avatar
I bought hypertech fan switch for my car and it isn't turning the fan on any early than it used to. I know if I ground the wire going to the switch the fan will come on, so I would think that would mean the switch isn't working? would having the stock chip in the car effect this?
thanks
Old Sep 9, 2004 | 11:20 AM
mako350Z28's Avatar
Re: Hypertech fan switch
You need to have the computer tell the fan to come on. That is why they recommend getting the Thermomaster chip, the fan switch, and the 160° thermostat together.
The whole package cost me about $240.
Old Sep 9, 2004 | 12:21 PM
95redvert's Avatar
Same here!
Old Sep 9, 2004 | 02:12 PM
88Irocker's Avatar
mine comes on at 210* and stays on until 185* - I believe it it a JET fan switch - I have the original chip in the car
Old Sep 9, 2004 | 03:46 PM
Scrote's Avatar
A TPI car has two or three ways of turning the electric fans on. One way is throught the Prom, the second with with the A/C or defrost (if aplicable), and the third is if there is a CTS located in the pass side head, these aftermarket kits only work on the cars equiped with the CTS in the pass side head. And only then would it comand the primary fan.
I just go through the prom and do it....Im lazy
Take care,
Erik
Old Sep 10, 2004 | 10:55 AM
doug791's Avatar
or if you get mad at it you can just wire the fan directly to a switch and turn it on your self
Old Sep 10, 2004 | 03:37 PM
Scrote's Avatar
Which will work well untill you forget to turn the fan on one hot day in traffic and overheat your small block.
Jeff'SS
Jun 1, 2015 06:21 AM
cristian1311
Nov 23, 2014 02:22 PM
troywg
Sep 12, 2002 07:28 PM
slothgrant
Aug 22, 2002 03:01 PM
