- Removing heat shield?
- spark plugs?
- what to look for when purchasing a camaro
- FS: (99-02) Whisper Lid
- LS1 Rearend is in! But I need help with brake related problems...
- turbos
- Borla muffilers?
- GN powered 1995 Camaro!!!
- Emergency Brake
- suspension problems?
- steering wheel radio controls
- SES upon highway deceleration...
- 3.8L Engine Misfires
- Must turbo charge
- How to remove the fuel rail?
- car is stuttering/stalling..
- me at the thunder racing shootout
- Where in the heck are the bleed screws??
- 3.1L pistons
- Tune-up
- LT1 in a 98 V6
- 3.73 Gears
- ?? about V6 3rd generation
- good suspension???
- Center console door
- Changing Valve cover gaskets
- new to the board
- Slaughtered
- roll bar
- pullys from rksport
- manual fan switch worth it?
- What size cam they put in the V6 60's?
- I Need To Know Where I Can Buy The Ultimate Clutch!
- heater
- I know this is the wrong section BUT!! I need to sell this ASAP!!
- a sad day...
- cams??
- Basic Mods ALL in major help
- Who has rear axle noise?
- oem clutch replacement recommendations
- shaky tranny
- 160 Thermostat
- Will this shifter go on my car?
- Where's it at?
- Vibrating worse each day!
- brake problems?
- car jerking and not goin past 45 all of a sudden
- Glow lights
- What mods should I do to my 3.1
- t top conversion manual
- cold weather startup
- Not your ordinary V6
- W68 appearance package
- Belt Squeek at gear shift
- Whisper Lid or CAI?or Both?
- Rear End Gears
- CAI or Free Ram Air Mod?
- Supercharged 3.8
- Head Work???
- ECU Programming
- Whisper LId?
- cam question
- When to replace clutch? Fog light replacement?
- Beta Tester Spot for Batman's S/C
- Does anyone make an aftermarket cam for the 3.8L
- A scooter wants to race me
- 3.4 probelms
- rear end ?
- Help with high/low beam lights
- Need to know quick...
- Burnouts
- How do i remove alternator? HELP
- Cai?
- SS Sway Bars
- Installing pipe in place of Catalytic Convertor...Need Answers ASAP...
- stalls
- Will these tires work on a 93 Firebird?
- hey guys, Im new, got a few questions
- wow sumttin is wrong
- Wrecked my car...
- Stock 3.8 Times? 5spd or A4?
- Why V6?
- What year did 3.8 come out?
- It's only a V6
- V6 Parts: Gauging interest....
- New times with the little v6
- z28 sway bars
- i have $80 credit at rksport
- im confused
- who make rebuild kits for thr 3.4?
- Good formula for a stiff suspension?
- how much is a radiator
- pics of my car comments ???
- i have some ?? that have no been answered
- SLP Cold Air or SS Hood
- Question about an odd setup
- sup
- I can't get the intake manifold off
- I've got Trouble...that starts with T and rhymes with...
- Can't figure out what this noise is coming from
- Dynoed the bird on the bottle
- Ran My Car
- V6 free mod question
- 3.4L Problems...EGR, Charging System...
- Exhaust leak in manifold
- took car back to track
- what kind of internal work can be done to a 3.8
- Just got 80 series on 3.4
- When do 3.4's die?
- 2.8L problems
- 3.8l rebuild
- Rear End Swap
- where did the link go for the v6 timeslips
- Wire Ohmage (?)
- V6 vs V8 springs Interchangeable???
- GM's 2.8- How reliable?
- Adding Zexel to non-posi rear
- Tach
- List for V6 to V8 swap, am I forgettign anything?
- 1 Piece Driveshaft
- v6 camaro vs v6 mustang 2000
- Superchip or JET Chip
- Brakes
- car alarm tech?
- Exhaust & Intake
- SLP Differential
- Torque Converter Install??
- I need a cat p/n? or aftermarket replacement? need help ASAP
- high mileage help!
- Emissions-WTF?
- Need Help. Tail light/blinker malfunction
- My 97 Camaro
- weather stripping and exhaust
- Torque converor?
- 3.8 vs prelude
- SES light
- Who says 3.4s are slow?
- Saw a 3.4 with 292k on it!
- its the thermostat right ?
- chipping results....
- T Top Leakage
- T-5 tranny question
- NEED HELP!! ABS Inop, Check gauges!
- Stock computer
- Cam
- Sellin the V6
- how much HP does k&n actually add
- Help with cat plz
- I went to a car show on Saturday
- Waterpump help/advice
- intake question
- Nitrous
- getting sick of 3.4 :)
- Cut Out on a 3.8?
- transgo encoutners....
- Body Kit
- Exhaust
- Gen I 383 Swap
- lowering springs and wheels
- 1993 Firebird V6 A4
- just bought a 88 V6 for 600 bucks
- 3.4 flowmaster exhaust sound clips
- 4.3L swap?
- if you have a Z28 or SS take off muffiler come on in>
- Will an SS hood it on my v6?
- 3.4l upper and lower intake manifold fs
- 3.4L Catalytic Converter going bad...
- Fan kicking in late
- High idle issues
- Whats wrong
- Whats the matter with this thing?
- I sold my car
- Oil question
- How long do drum brakes last?
- Drum Brakes
- 455 Engine
- conclusion...
- woohoo!
- Electric Superchargers
- Throttle Body
- Crank Hardend
- Exhaust
- crazy spedometer
- How do you remove the wiper arm?
- SES Light
- MSD Ingnition Box
- Plug wires????
- axle problems?
- Power Window motor replacement
- Water Pump replacement help!?
- running rich
- Brake fluid etc.
- Supercharged V6 f-body with TA/SS bodywork?
- Changing brake pads?
- Does anyone know when the ATI procharger kit is coming out?
- how much is my 6 worth?
- '90 FB 3.1 Questions
- dummie lights
- adding power windows
- looking for OBD1 laptop software
- Vibration and stuttering...
- spark plugs/wires
- Exhaust....
- New Clutch
- Just a few weeks left....
- headlight question
- big shot nos on 3.4L
- Roller Rockers
- General Info
- SLP free ram air induction?
- T_TOps
- 94 3.4 L to 95 LT1 conversion
- targa tops
- SS Hood
- Fog Light....
- what next...???
- 3.8 to LS6 swap
- need everybodys opinion. plz
- Secruity Disable
- alternator question
- Weight Reduction
- Power locks question
- Somestuff to laugh at..........just cause it Friday
- Emergency brake question
- Is dual exhaust possible...
- ws6/ss exhaust opinion
- Hypertech Power Programmer III for 00-02 V6s
- Imports!
- Differntials
- Repairs?
- The monster is the TRACK!!!!! Got 3rd in the trophy.
- Body kit ?
- Has anyone ever....
- swapping a older 350
- Check Engine Light = NO HORSEPOWER
- Is It Possible ...
- Wiper Help
- How much HP can a 3.4 really make?
- How do you tell if the cat is bad?
- Where to buy aftermarket heads,cam,intakemanifold for 3.4?
- just wondering
- Its been a while since our last So. Calif. meet-up.....
- New Mustang Saleen
- new here
- help with 3.8
- New Sig......
- Killing the monster!!!!!!
- What brand of catalytic converter and y-pipe should i get?
- I OWN the idiots at Ford who did their website!!!!
- Corbeau Seats
