View Full Version : V6 Tech
- RPM is too high, help
- New Cat, now getting code 420
- camshaft sensor? for 3.1
- lower oil pressure
- exhaust question
- NEED help !! engine hellllp!
- 3.8 V6 off road
- Throttle pegged this morning, VERY HIGH IDLE :P
- Spark Plug Question
- Engine is loading up....
- anyone know?
- How do I?
- A/C Compressor
- Factory Service Manual
- My Cars on E bay for one more day!
- Compustar Pager
- Fuel Line Disconect
- 3.4 with security problem
- Exhaust headers
- V6 Auto Trans
- Gaskets, Dex-Cool, Leaks & Warranty
- 95 V6 vs Z28
- video problem with"v6"camaro video
- 3.4 CAI on ebay
- Help! 96 3.8 V-6 engine "Locked down"
- NOS2006 appreciate your help bud
- Washed Engine - No Start
- what can i do to get my 1997 v6 to perform better for cheap??
- 2 questions
- v6 to v8 engine swap
- Ignition Type - late 90's V6
- New V6 3.8 Motor In So Cal area?
- V6 Chev Vortec Restrictor Plate Engine
- 96 cCamaro For Sale
- digital horsepower tuner
- 1997 v6 supercharger or turbo??
- VATS system wont let car start...
- 3800 interchange-ability
- does powerbraking a manual burn up the clutch???
- 3.8 misfire
- BAD cooling problem in 94 camaro
- Car Bogging in 2nd Gear?
- Anyone who has tuned their pcm. HELP ME
- How much would headers and a high flow cat give me????
- Performance Chip????
- 91 Camaro 3.1 to 3800 swap??
- Code P0420 - help!!
- 96camaro
- do u guys have these starting issues please read every1
- Need to replace CAT 02 Firebird
- how do i make by engine faster for cheap?
- 94 3.4 problems
- 3.4 V6 Misfiring
- Possible EGR problem
- Yet Again Another Problem!!!!
- 99 firebird 3.8 tranny hard shift from 1st to 2nd
- What the heck?? *photos*
- Shortblock Upgrade
- Engine misses when weather is hot & humid!
- quick question
- are the fwd intakes (upper and lower) different that my 3.4
- 98' For sale in NJ, LOW MILES, VERY clean!
- Radiator Question
- Normal Launch causes drivetrain flex?
- wheel speed sensor
- Does anyone run COMP roller tip rockers on 3.4 V6?
- 98 3.8 complete intake,tranny,heads,block cheap
- Camaro 3.8 work in a FWD GM car?
- can i use the intake off this car on my 3.4
- V6 2.6L(89 RS) to V6 3.0L(90 RS) Engine swap
- headlights grinding
- 5k and cant find a shop!
- turbo kitty or no?
- f41 ???
- Would a 155 speedo work on a 2001 v6 camaro
- can someone with knowledge work with me on a 5.3 lsx swap
- thermostat
- 91 Firebird, Replaced Starter Now Runs BAD, Help
- 3.4V6 underdrive pulley
- engine idle help me
- can i use a 96 v6 cooling fan on my 3.4 95
- o2 sensors on a 97 camaro...SES light
- Starting issues...
- 3.8 with Dynomax
- 2 Quick Questions
- performance chip
- LT1 TB on 3.8?
- strang noise
- 3.8L to 5.7
- heat meter
- one of the nicest v6 camaros out there.
- a/c system problems
- Oil pan Gasket
- 3.8 toast Waterpump ?
- Quick reassurance question
- Chip For 3.8?
- Camaro 3.8 Headers
- burn outs
- Antifreeze
- ported/polished TB on today!! (pics inside!)
- piecing together a summit 3" exhaust-help with cat (muffler replacement?)
- 3.4 to 3.8 swap
- true duals
- Intake Manafold
- rattling noise
- cheap better sounding exhaust
- mods list
- Coolant temp sensor connector wiring?
- Engine is making a loud clicking sound...help!
- auto to manual swap.......
- what is the Y87 performance package?
- temperature gauge
- Oil Pressure Gauge
- spark plugs
- I overtightened my waterpump on my 98 3800 do I have to start over?
- 01 Camaro V6 with a stock Camaro SS exhaust
- Stump the Chump (Experts)
- flowmaster
- lever under drivers seat?
- 3.4l suggestion on add ons
- K&N FIPK 3.4 or 5.7?
- Msd
- egr vaule problem
- Who has the highest mileage V6 fbod here?
- desent headers for a 3.8firebird
- Borla
- 3rd Gen V6
- Will Pacesetter's make me lose low-end?
- Changing center consoles
- Is a 98's Wisper lid and K&N worth anything?
- Blackouts on black camaro?
- 94 camaro cuts off after a while
- Exhaust options needed asap!
- new here, have a simple question
- Building a fast 98+ V6?
- why do these cars come with 2" stock exhaust?
- Will a catback help me that much?
- I hate v6's...............serious
- Good Pass
- Went to the strip
- Cams??
- Starter Motor/ Alarm Help
- Need Help Radiator Hose
- just saying hello
- anthor missfiring problem
- 2001 camaro v6, 5pd 60k $400.00
- New here, have a question or two...
- rocker arm adjustment on 3.4 L
- what else would i need
- Aftermarket Y-pipe?
- V6 supercharger compatability
- if anyone knows of a....
- one day left for v6 parts on ebay
- FS: 1996 Camaro 3.8l
- Msfiring? No Codes!!
- Jet Performance Chip Questions
- What is my problem??? Help!
- 3.4L mileage to the tank.
- What type of oil?
- 3.4L v6 HELP
- 3.4L v6 HELP
- Has anyone tried?
- Any Suggestions?
- Magnaflow exhaust questions
- 184rwhp/212rwtq...
- 3.4L parts and zex nos kit for sale
- Throttle Position Sensor
- low-side A/C hook up
- Rear gears?
- Exhaust Manifold Heat Shields...
- weird feeling while driving..wtf?
- Wrist pin problem
- Head bolts: TTY?
- Oil Life Monitor....
- Need Help
- hood scoops (DIY)
- quick question for exhaust
- cold air kits? better gas mileage? or worse?
- SES light....
- anyone have a hood?
- GMMG exhaust?
- showing off the ride!!!
- SLP Cold Air Intake
- superchargers and blow off valves
- More pics of my new 1997 5-speed v6
- My new car pictures 5 Speed!
- a few questions...
- Need Help Asap!!!
- 2000 V6 camaro...aftermarket underdrive pulley
- 3800performance.com question
- NEW 5 SPEED V6 Camaro
- remote oil filter on 3800SC
- electronic spark control module???
- increase lift on stock rockers?
- engine hesitation
- 98+ driveshafts
- suddenly won't start
- 25mpg LS1...Is it possible?
- Check Engine Light
- Ignition problem
- Oil and Water
- Do Carseats fit???
- Going Z!!! Care To Help???
- 100,000
- edelbrock cams????
- How do i get this piece out?
- Engine whining
- Engine questions
- Difference between 1998 and 1996?
- will this work?
- 3.4 Power Steering Bolts
- 3.4 stock exhaust information
- Supercharging a 3800
- 4.3l Vortec
- Need More Power!!
- Slave Cylinder Question
- ***flaming Fuse Box!!!***
- K&N Oil Filter: Low pressure???
- BOSCH +4 Platinum: Yea, or nay?
- 3.4L '94 camaro
- is this car normal?
- blown gasket heads! possible water in engine! need help!!!
- Cam/Headers/Tune/Rear-End/Swaybar all Done!
- 3.4 engine help
- remove the cat conv. from a 98 3800?
- Fan Switch
- Rear disc swap!! finally!!
- SS Hood on V6
- P&P stock Heads
- Misfiring?
- alarm on 97 firebird wont stop going off!!!
- I have three problems.. please help
- Installed Cam/Headers
- 3.4L headers
- quick gasket help.
- 97 v6 auto gears
- 1997 v6 auto at drag strip
- converting an auto to a manual
- Fuse help
- Mileage
- What should I do
- Want to convert
- Searched, found, gotta ask anyway.
- Cometic or Fel-Pro head gaskets?
- 1998 V6 camaro wont do a burn out....
- Why cant my 1998 V6 Burn out????
- Weird Problem with my V-6 (won't start sometimes)
- 2.8 mfi to 5.7 tpi conversion
