PDA
View Full Version : V6 Tech
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23
  1. rear main seal
  2. Reprogram computer for a different year trans
  3. Firebird 3.4L problem! Help!
  4. Ring and pinion set installation questions
  5. Is bad U-Joint causing my humming/howling? [PICS]
  6. I have a 1999 Chevrolet Camaro 3.8l thermostat question?
  7. Problems after hosing my engine off!
  8. just picked up my new car
  9. 99 V6 w/70k miles, trans flush or fluid change?
  10. Crankshaft timing gear question
  11. re-using intake manifold gaskets 3.8
  12. 1999 Chevy Camaro 3.8l mods?
  13. Rear wheel bearing -- can I remove the axle myself?
  14. ls1 driveshaft?
  15. Thermostats?
  16. Headlight Casing Bolt Problem
  17. Harmonic Balancer question
  18. 3.1 Bucking Violently
  19. Low oil pressure
  20. Multiple cylinder misfire Question..
  21. Panhard Rod??
  22. 3.8 internal or external balance engine
  23. V6 or V8?
  24. check engine light again
  25. Check engine code p0440
  26. Will this do anything performance wise for my 3800 camaro?
  27. Turbocharger for a 1999 camaro 3800?
  28. rear end
  29. Need Help Finding The Problem With My 99 Camaro
  30. Evap purge error
  31. V6 to LS1
  32. 3.8l turbocharger???
  33. throttle body
  34. Help Help Help Anybody
  35. Damned rpm spike is back
  36. I have a 1999 Chevrolet Camaro 3.8l. I want to make it faster?
  37. Alternator noise on 2001 3.8
  38. Changing 96 to a 97
  39. if you recently changed plugs/wires-misfire warning
  40. Y Dos Every 1 Say That V6 3.4
  41. spark plugs
  42. EGR Valve question
  43. Help Rough Idle
  44. how do i now if my firebird has TCS
  45. ABS Module question?
  46. I'm sellin my Car, The post is in the for sale section
  47. installing gauges
  48. 3.1 Operating temp?
  49. I GOT MY refund back
  50. shudder/shake in gear 98 3.8
  51. throttel body
  52. Anyone swapped the 3.4 into another platform?
  53. pcm tuning
  54. 94 Camaro v6
  55. I respect the 3.8
  56. Gotta 2.8l question for ya
  57. 2.8l V6 question
  58. My car dies when i turn...
  59. Turbo Kit for 3.8
  60. the 3800 f body with a GTP supercharger??
  61. what are the 1/4 mile times for a stock 3.4
  62. Quick connects for coolant reusable?
  63. Want the car BUT Code P0420 and rough idle!
  64. Can i take off my ecu on 92?
  65. distributor to coil packs
  66. Project: Camaro
  67. need a direct fit 99+ fuel pump
  68. cylinder map for 98'
  69. 98 Burning Smell
  70. drivers window stopped working on 97 V6
  71. coolant problem
  72. Differences in fuel pumps
  73. finally fixed the problem
  74. 1996 3.8L Miss
  75. 2000 V6 3800 Camaro ?'s before purchase
  76. Best Exhaust???
  77. Stalling, Idling Issues
  78. well the Camaro is in it's death bed
  79. looking at a 99 3.8, any tips?
  80. (95 auto tranny in a 96
  81. Catalog
  82. Stock or Performance
  83. Now What?!?!
  84. MAF cleaning?
  85. Help!!!
  86. 3.4 swap probs
  87. battery drainage time to ask the experts for help
  88. Have a brake light issue...
  89. 94 camero 3.4 idle *please help!!!*
  90. non-fbody.....gm 3.8L v6 timing chain swap
  91. $70 Electric SuperCharger??? Do these work?
  92. $70 Electric SuperCharger??? Do these work?
  93. p1518
  94. Is $550 a reasonable cost for EGR valve/gasket replacement on a 3.4L...
  95. p1404
  96. 1998 Camaro - wont start
  97. odd noises from air intake system 97 3.8
  98. What does Missfire feel like in a V6?
  99. 1997 3.8 heater core
  100. 3.4L idle problem
  101. is it ever safe?
  102. Starter problem or Flywheel problem
  103. pressure plate torque specs?
  104. Msd Dis 4
  105. Stock 3.8 coil voltage?
  106. New Engine
  107. Oil smells like gas???
  108. New O2 Sensors Improve gas Mileage?
  109. An auto-start alarm
  110. Any cars other than the Camaro that have a 3.8 and 5spd
  111. ls1 into 89 rs camaro
  112. Newbie
  113. coolant lines that goes into head
  114. starting problems 1994 3.4L
  115. 4.3 vortec
  116. v6 95 to 350 injected
  117. for those swapping motors
  118. 95 Firebird Hard Start Smell Gas Goes Dead At Times
  119. start problems
  120. hi im new w/ a question
  121. heater core question
  122. hey guys i was having a problem
  123. original cam specs of a 95 camaro
  124. Toss Up....
  125. new and getting a car in two weeks!
  126. v6 fuel injection to 350 carburetor
  127. Code P0001 and P0003- Is this a bad fuel pump?
  128. Code P0001 and P0003- Is this a bad fuel pump?
  129. Coolant leak at TC
  130. Oil pan gasket change
  131. Differential decode ???
  132. help!!!!
  133. Any of you guys looking into swap in a LT1 - Look in here
  134. bogging when stepping on gas
  135. start up
  136. owners manual
  137. Need a bolt size
  138. Can The Suspension Out Of A 95 Z28 Wk In A 86 V6 Camaro?
  139. Installing dampener... how deep on the crank should I go?
  140. 1998 camaro Stalled no start
  141. Timing cover gasket set... where to these others go?
  142. 3.4 Oil Pan
  143. 1994 V6 overheating...
  144. Need some engine swap info
  145. 3.8 fuel pump
  146. Water leak
  147. 98 3.8L Fuel pressure
  148. looking at buying a V6 F-bod, what to look for
  149. "reduced power light" keeps coming on
  150. v6 5speed for sale
  151. 3.4 no fuel pressure.
  152. rear main seal
  153. Who wants some TT, Garrett T25's FS
  154. 98 Firebird 3.8L p0301 rough idle
  155. stupid misfire
  156. 2000 3.8 V-6 Oil pan?
  157. 94 camaro v6 water pump replacement
  158. Simple question about 95 V6 exhaust...
  159. 231ci. V6
  160. 1994 v6 3.4L 50mph service engine soon light
  161. 1995 3.4 and I need to change the thermostat
  162. what are the power gains with this mods
  163. 99 3.8 stalling and weirdness
  164. 94 and 95 3.4L
  165. 99 Service Engene Soon Light
  166. 3.8L Dipstick question
  167. oil pressure gague going crazy
  168. rear defrost problem
  169. Disk brakes on V-6's?
  170. is this cam kit any good
  171. Brake Recommendation??
  172. Loud Wooshing Sound From Engine Bay Above 3500 RPM's
  173. Stumped
  174. New To The Fourms few questions
  175. check engine light
  176. 3.4L ported throttle body, K&N FIPK, 18" Vette wheels for sale!
  177. Is this V6 Worth Buying? Can it be supercharged/turbocharged?
  178. Throttle Position Sensor
  179. Unusually high oil pressure...
  180. Plugs not firing at high rpms?
  181. How Much HP does a 95 V6 3.8L Have?
  182. 93 3.4 cold air intake
  183. is there any technical service bulletins for 95 3.4s
  184. A/C not working
  185. 98 v6 engine replacement
  186. A/C works again finally
  187. Backfire, misfire, jump, skip......
  188. Need Help with a fan...
  189. Practical, Cheap, Do it Yourself
  190. is there any cams for the 3.4s
  191. suspension question
  192. 99 Camaro random misfire code
  193. Its Time
  194. v6 problems in friends car..
  195. V6 conversion in a Nash
  196. are they worth it
  197. 96 3.8 dies after a few hours of driving
  198. What would a V6 do with a T/D Exhaust Setup?
  199. Squeals AFTER turning on AC?
  200. Likely source of oil leak
  201. Non-Mechanic Translation Needed for Upgrade Guide
  202. P1441 problem
  203. flowmaster 40 series on a 96 3.8
  204. Romping when I start the engine in the morning
  205. wtf?
  206. bogging at full throttle
  207. Oil Pressure Sending Unit???
  208. Hypertech problems issues
  209. Gasket Problems
  210. my 95 3.4 VS 95 3.8 stang
  211. Need help with 3.4L engine knock
  212. Questions on what to buy. Or not.
  213. 96 3.8 to 94 3.4 swap
  214. have to do some work on a 98 V6 car, questions on plugs/wires
  215. popping sound
  216. Vendor evaluation questions
  217. Oxygen sensor performance question
  218. air fuel ratio gauge
  219. Scrapping noise
  220. 96 rs vs 07 mustang v6
  221. i need help with my 96 rs
  222. 1997 v6 CAI question
  223. 3.8L supercharger
  224. Power Steering Quits
  225. 99 3.8, rought idle, oil in tb
  226. How reliable are the 1995 3.4 v6 camaros?
  227. How to change spark wires?
  228. Supercharger on 3.8
  229. 3.8 Cam Specs
  230. 3.4 coolant temp sensor and gauge question
  231. 1999 Camaro V-6 to V-8 Engine Swap
  232. why go V8
  233. 95 3.8L cooling question
  234. gauges going crazy
  235. 3.1 questions???
  236. 3.4V6 1995 4th Gen not starting properly
  237. Cooling Problem
  238. crankshaft position sensor
  239. another missfire issue
  240. 94 3.4L idle problem
  241. Questions
  242. kind of an odd question
  243. Cooling Fans Won't Kick On!
  244. Why the 2 piece drive shaft ?
  245. Sputtering when stomping on the gas?
  246. Help. The 3.4 is overheating.
  247. 1999 V6 Studdering and throwing codes
  248. a/c problems
  249. throttle position sensor
  250. V6 ??? i thought this was z28
