Killing the monster!!!!!!
Old Sep 23, 2002 | 12:50 AM
All_InTheRED's Avatar
Its been buggin me.........
........the HP eating monster that has taken up residence in my camaro.
I want to evict him!
......but how??
Cat??? I have 2 extra less than 1K mile old 3 inch Hi-Flo cats from the Oldsmobile. What are your thoughts about have a 3inch cat with the 2.5 inch catback??
Plugs??? AC Rapidfires. But they are ok.
SES lights? There are none
Ideas my brotheren!!! Suggestions!!!!!
Old Sep 23, 2002 | 09:05 AM
94z28jbw's Avatar
Question
You're talking about this problem like it's a monster hidden in your engine or something. It's a machine; if their is something wrong with it, there's something wrong with it.
What is you're car doing? Or even a better question; not doing?
Old Sep 23, 2002 | 09:59 AM
MustangEater82's Avatar
Pop the CAT off, and run it open Y-pipe, I know it will hurt your performance in the long run, but I ran 16.2s like that, maybe on an average car 16.8s, either way if you run a little better, then maybe its shows its somethign wrong with the exhaust, system. Its jsut one exhasut clamp, and alot fo rust.
Do you have a multi-meter, I hear there is a way to test your TPS, maybe its sending a signal of half throttle instead of full, I planning on checking mine out along with any ohter sensor I can with my chilton's manual and multimeter, also may want ot check the coils out.
Old Sep 23, 2002 | 09:14 PM
#7's Avatar
Hey the guy w/ the Z obviously wasnt around last week,we got it Red.
Anyway you asked for "thoughts" I think the Cat is worth a try,my though is...Cats restrict flow regardless,and a 2 1/2" cat on a 2 1/2 system ,the cat lets it by slower(normal)
But with the 3" I see better chance of increasing the velocity passed the cat(maintaining the intake volume & velocity,or close to),b/c it starts 2 1/2 ,ends 2 1/2(exhaust& Y)the restriction spot now 3"cat.,has more filter mass to process 2 1/2"s of exhaust,Quicker.Especially since its a high flow to boot
MustangE I do that too...You can tell on alot of things if they're bad,somtimes you may not even know.
All_in red,I still (since you drag) Think you should squirt
T.
Old Sep 23, 2002 | 10:30 PM
Tiago's Avatar
forget about finding a monster, install a monster 396
Old Sep 23, 2002 | 11:33 PM
Well stopped by the Chevy dealer tonight, drove a 02 Z28.......wow.
They had one for 19K......and another for 22K.
But in the meantime, gonna do some checking tomorrow and see what I can find.
Thanks for the ideas BROs!!!!
I'll keep ya posted.
As for "juice", might not be a good idea if there is fueling problems now
.........just might have to put in a 396 after that
Old Sep 24, 2002 | 12:52 AM
PitySister's Avatar
i wish i would have spent the extra $5k....and gotten the z28
don't know if the bank would have approved me for that or not though
Old Sep 24, 2002 | 01:06 AM
hehe kill one monster with a 396 monster, sounds good to me
Old Sep 24, 2002 | 04:09 PM
TPS checked out at 4.33volts at WOT, and .53 at throttle closed.
Old Sep 25, 2002 | 12:05 AM
#7's Avatar
should be 5 volts@Wot,less than .5 volts closed.
Old Sep 25, 2002 | 01:14 AM
check the voltage of the wireing harness to make sure its gettign proper voltage too.
Old Sep 25, 2002 | 02:24 AM
The TPS checks out ok
Gotta see if I can find my FI fuel pressure tester. Gonna check the Fuel Pressure next, and then try and get into the MAP sensor next.
Old Sep 25, 2002 | 01:01 PM
Fuel Pressure checked out ok. 46psi max pressure. 38psi running pressure.
Vacuum checked the car too.
Idle Vacuum 18psi.
Snap Throttle 24psi
.....but here's the "hick-up"
In park....at 2200 rpm......20psi.
In drive...at 2200 rpm......8psi steady.
I think me need to go to the "pound" and find me a new ***** "CAT".
Old Sep 25, 2002 | 02:07 PM
Tiago's Avatar
its not psi max, its inches of mercury
Old Sep 25, 2002 | 05:20 PM
yeah yeah
