car jerking and not goin past 45 all of a sudden
Old Nov 3, 2002 | 12:55 PM
certifiedlt1's Avatar
ok guys my friend has a firebird not for sure of the year prolly around a 94-96 at the newest, and at 45mph it jerks and wont go any faster, any ideas?
Old Nov 3, 2002 | 01:13 PM
1fastV6's Avatar
maybe time for a tune up? when was the last time the plugs and wires were changed?
Old Nov 3, 2002 | 01:47 PM
ImportKILLER's Avatar
Allow me to quote your signature...
"anythings possible,nothins for sure"
Need more info on whats going on in order to pin point the problem.
Old Nov 3, 2002 | 02:06 PM
Marky82's Avatar
Fuel Pump may be going??????
Old Nov 3, 2002 | 03:58 PM
oil pan 4's Avatar
Like he said how is the fuel pump?
It is not getting enough fuel.
The filter could be cloged. Some injecters could be cloged. Psi reg could be mesed up or stuck.
A sencor could be mesed up not letting in enough fuel.
Old Nov 3, 2002 | 07:03 PM
ibanez6rg's Avatar
Man, you should probably have that checked out...Would suck to go only 45
Old Nov 3, 2002 | 10:05 PM
cobra2550's Avatar
well he doesn't need to go faster than 45
Old Nov 4, 2002 | 11:15 AM
94TeALFiReBiRd's Avatar
plugs or wires i think!
Old Nov 4, 2002 | 07:35 PM
atl2001's Avatar
From: carbondale IL \ Alton IL (outside St Louie MO)
the cat could be clogged, something to think about
Old Nov 5, 2002 | 02:52 PM
1fastV6's Avatar
let us know when you find out
Old Nov 5, 2002 | 11:27 PM
SuprSpdDB7's Avatar
From: Vero Beach, FL / Tampa, FL (USF) / Holbrook, NY
i had the same problem....
the problem was the cat being clogged!
i changed my fuel filter, plugs, wires, everything! then i put a new exhaust system on and problem solved!!
just go to summit racing and buy a $60 cat converter and you problem should be solved!!!
Old Nov 5, 2002 | 11:52 PM
2000redSS's Avatar
I had a similar problem it turned out a piece of plastic was stuck in my throttle body, don't ask. But its worth it to take your airbox off and check to make sure the throttle body is clear.
Old Nov 8, 2002 | 07:49 AM
Barry00Bird's Avatar
I hade the same problem, clogged Cat.
Old Nov 8, 2002 | 10:11 AM
94BlackBowtie's Avatar
My first guess would be a clogged CC...
but my worst case guess would be a busted internal sprag gear in the tranny...
Will it shift through all the gears?
How many RPM is he turning at 45MPH?
Is there a funny smell?
Does the exhaust sound any different?
Old Nov 8, 2002 | 11:00 PM
Maxxresist's Avatar
I just put the ex old ladys new 3.8 in her 96, My first words after turning it over to her " Get one more ticket, or one more oops, and ill put a throttle stop and youll be doing 35 everywhere, including the freeway"
She smiled and said she was glad I cared, but new I would do it.
Reason it got a new motor was from one of her oops's, and then decided to keep right on driving for a week or 2 with a busted radiater and no water, her " The temp needle thing never went up, its not my fault"
Friggin woman!!!!
Garcia5
Jul 7, 2022 06:51 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
Ricardo
Nov 29, 2014 10:58 AM
blac94Z
Nov 24, 2014 07:12 PM
USAirman93
Nov 24, 2014 03:37 PM
