View Full Version : V6 Tech
- Difference Between Corvette and Camaro (V6) Intake
- 94 3.4 help please
- new times
- What are some cheap mods?
- 97 3.8 Starter swap
- Help a noob
- camaro rs.....?
- rpm cuts off at 4000!
- ? about taking on a RX-8
- temperature sensor tricking
- Egr Valve?
- Help with Carfax? PLEASE!
- Strange Throttle Response...
- Weird hissing noise up front?
- small block into 1994 Camero
- Misfire at WOT, cylinder 1, done a whole lot, HELP ME!!!!!!
- 456 RWHP 509 RWTQ 3800 camaro
- help on some shocks... (descision)
- 96 PCM question
- Pinion Seal
- new turbo for v6's
- Resonators
- ODBII code p1406 when it gets cold out
- Weird bucking
- 1987 Gn
- Magna flow Direct-fit
- 3.1 Help Please
- New Intake for 3.4L
- camaro/gtp
- 3.73 Gears
- Slave Cyl Brackets ????
- How fast are camaro/bird v6's?
- exhaust problem?
- Thinking of creating my own borla plate>>>
- How many 02 Sensors?
- Some insight into the 3.4L OHV RWD motor
- B & M Shifters
- 97 RS 3.8L supercharger
- camaro vs GTI
- Cold Air Intakes
- Overdrive or not
- k&n for '02 grand prix gt NOT gtp
- rocking bad at constant rpm speeds
- What other car models use the same 3.1L V6 that's in the 90-92 Camaros?
- broke the T-5 at the track
- ABS INOP light
- Anyone got a cam'd 3.4?
- Brake problems after V8 swap
- Rev limiter on a L32 V6...
- Scared of New Sound With New Muffler...
- 01 V6 - Have to turn key about 30 times to start
- Fuel Pressure Question
- 3.4 cold idle/clutch problem
- Belt tensioner assembly
- need to replace lifters?
- Tail Light Woes - Process of Elimination
- PCM scanning software
- 1995 3.4L Losing Coolant rapidly
- If your looking for a 3.8 with some mods..
- 3.4 running rich upon startup, please help...
- 3.4L camaro won't start sometimes when hot?
- Are headers really worth it?
- 416 RWHP V6 camaro!!!
- 3.4 w/at ... parts must go!
- Injectors on a 3.4 V6
- Civic or Cam project?
- New tuning forum
- After a week of driving "slow" to get the best MPG I got....
- Help me with my 3800 series v6 engine!
- new exhaust
- 99 camaro 3800 issues
- high idle
- Upgrades? Which ones?
- Wiring harness
- best, rice free camaro 3.4L exhaust?
- Flowmaster 40 on a V6?
- have to replace shocks and struts
- Mass Air Flow Sensor Location
- Stock GTP boost?
- No Injector pulse, help!
- Can I.......
- Engine going out????
- 3.4L misfire and poping
- wanna go with headers
- dropping a 3800 into my Isuzu
- is this a trusted site
- help SES light on Code wont clear
- Please Help With Valves
- Terrible gas mileage (weather? whisper lid?)
- walbro PSI fall off
- n00b ?? wheels and shocks
- PIMP my Ride!
- NEED 3.4 to 3.8 swap info... no "get a v8" stuff
- Hia
- Where to get my car's chip programmed?!
- V6 3.4l Overheating.....
- 98 3.8 question
- Turbo Installed
- sparkplug changing on 3.8 firebird
- need help with my 94 camaro
- Good Performance Ideas?
- car won't start unknown problem help please!
- 95' Camaro 3.4l NEED HELP PLZ ! Knocked Something off the oil filter assemely ???
- A/C system
- I need a online Guide for changing all fluids in a 95 camaro 3.4l v6 ?
- Where is the Fuel Filter on my 95 3.4l Camaro
- 95 3.4l V6 Raditor Flush how to ?
- Reliability with 159k miles... what to do???
- looking for a teal v6, how hard are they to find...
- 1997 Camaro RS
- overheating + ac problem
- all 3.4l performance mods?
- 94 3.4l no muffler! future no-cat?
- Sound Or Video Clips
- Check engine light...scanned
- running richer
- V6 BLocks
- Magnaflow exhaust
- 94 V6 3.4l
- IMPORTANT: Those with Taylor wires
- 3.8 supercharger
- my friend is in need of your help!!!
- 95 3.4L Overheating... I need help!
- code
- is 3.4 worhtless?
- weird smell
- stock V6 Camaro springs
- turbinator
- revs climb by 300rpms when i tap the gas
- gay ass wires $hit balls ufck!
- gauges arent working
- dual exhaust on v6
- Flowmaster 80 series over a 40
- What's it worth?
- New Camaro Owner
- Speakin' of EGR valves...
- just got hit, now some wierd problems
- 92 camaro RS
- Weird Voltage Surge problem....Help
- headers again
- air intake
- What next?
- My camaro is overheating at highway only.
- 3.8l Turbo!
- buying a 94 v6 maybe
- upgrades for my first Camaro
- Cam
- Help!!!!!
- Will a 95 t-5 tranny fit in a 98 and up fbody?
- Yet another spark plug question :D
- Whats up w/ Shift Kits?
- Trouble Codes
- 1994 3.4 camaro vs 1994 3.8 mustang
- Cat back pipes
- what should i do?
- A/C Evaporator '97 3.8L
- fuel filter
- rebuilding a v6
- Demodding car due to accident ! ! !
- Spark plug change
- No Compression???
- Mild cam in 3.4?
- 3.4 Thermostat Restrictions?
- turbo
- Driveshaft Problem
- SLP intake fitment
- starter problems
- RK Sport air temp module
- 1992 camaro 3.1 still overheating.... wtf?
- What would these power increases be?
- Plug and wire question
- Where to buy CAT?
- need help with door
- what grade of gas?
- Oil Pressure Problem.
- no o2 sensor bad?
- Magnaflow or Flowmaster?
- Ok Please HELP!!!!!!!!! time sensitive
- Is this a misfire?
- Turbo kit for sale (all 3.8l engines, new kit)
- Spark Plug Wire Gurus in here
- Egr
- Taylor Wires question
- Problem DTC code
- Valve Covers
- look what I got yesterday
- 6 or 8?
- Looking for a button.
- Idling Problem
- Hypertech/160
- 02 sims for the 1 wire 3.4
- Replacing Gaskets in 3.4 (relieving fuel pressure)
- temp sensors
- what gas mileage do you get
- 93-97 conversion to 98+
- 2000 Camaro mods
- 1 spark plug is giving me some trouble
- Gas Mileage Now what it should be..Suggestions?!
- 3.1 V6, Bolt Ons
- OMG i'm changing my spark plugs
- which wires are better
- 1994 Firebird 3.4, Some Questions
- misfire/plug question
- Post your cardomain here
- 3.4l muffler removal?
- Help!
- 3in Exhaust on a 3.4...it worked!
- I want faster window motors
- (POLL) Push botton start
- Hi everyone
- Mysterious Coolant Leak...
- 1993 v6
- Aftermarket Crankshaft??
- does a broken catylitic converter slow you down
- Randomly doesn't start
- Steering Wheel
- Need Help
- Cheaper replacment for stock fuel pump
- No fuel pressure please help.
- cams
- Shifting Problem
- quick question about k/n intake...
- 2000 3.8 shift light install
- rev limiter
- 3.8 headers
- 3.4 to 3.8 swap?
- Intense cam for my V6 Camaro
- Can i replace my two piece drivesaft with a one piece.
- Alternator question
- Exhaust sounds like rice... help?
- Installing Shift Light
- WS6 Exhaust on a v6?
- overheating HELP
- Dont know what to do with this car
- Spark Plug Help
- Fan Motor replacement? help
- 1992 3.1L overheating need help.
- Ls1 Throttle Body V6 Camaro
- Transmission Swappage (due to slippage)
- fuel pressure regulator please help!!!!!
- 94 v6 camaro
- Is this a good buy?
- Chambered muffler or bullet muffler?
- Borla
- Help me please
- Rear End Swap (LS1 to V6)
- Which High Flow Cat is better?
- OBD-I v6 Camaro Software
- dont know what to get
