Emissions-WTF?
Old Oct 16, 2002 | 01:29 PM
CARdiac's Avatar
Emissions-WTF?
I just moved to TX and for the 1st time I had to have my 3.4 inspected. Well I failed emissions . This I do not understand. My cat is <1 year old (3" Catco), the O2 sensors were put in at the same time as the cat, the plugs are less than a year old, the EGR is >2 years old.....The really strange thing is, when I disconnected (I installed a switch) my Jet chip, the Hydrocarbons then raised over the limit and the NOx increased even more.
1. Why would I fail emissions with a new cat and O2 sensors?
2. Why would the emissions increase even more w/o the Jet chip? Did I not allow the computer time to compensate? But does it need time to compensate when it gets reset due to the loss of power?
WTF?
Old Oct 16, 2002 | 03:43 PM
All_InTheRED's Avatar
The Smog Tech is in!!!! (really I am )
I need the actual numbers and rpms. Also was it a dyno test or two-speed-idle test (no dyno).
Old Oct 16, 2002 | 04:12 PM
CARdiac's Avatar
Dyno'd
High Speed 25 Mph RPM 1679----Low Speed 15mph RPM 1687
---------Standard------Mine---------------Std------------Mine
HCppm----117----------46-----------------120*********126
CO%-------0.65---------0.14--------------0.67------------0.52
CO2%--------------------15.3----------------------------14.6
O2%----------------------0.2------------------------------0.5
NOxppm---821----------799---------------907*********1672
Dilution%--->6-----------15.4--------------->6-------------15.1
PLEASE help ME!!!!
This is w/the Jet Chip off
Old Oct 16, 2002 | 05:09 PM
is it like here in Calif. where the 15mph is done 1st and then the 25mph???
If it is..........its just the cat and o2's were not hot enough.
Did the car idle alot or sit shutoff before the test???
Old Oct 16, 2002 | 05:33 PM
CARdiac's Avatar
I took side streets not the highway to the shop, and yes it did sit for a while before it went in.
Yes, Houston does have the same emissions as CA.
What do you recommend?
Old Oct 16, 2002 | 05:48 PM
ImportKILLER's Avatar
My test was at two speeds:
Idle and I believe 2500 RPMs...
Old Oct 16, 2002 | 08:45 PM
Being as how it sat (engine off).........the cat cooled off. Once it got warmed up..........the emissions dropped (hence it passed the 25 mph)
Also, it wouldn't hurt to disconnect the batteries over night.......just to be sure that the PCM isn't operating off specs it "learned".......drive it a day.......to relearn.
Once there, DO NOT shut the car down....let it idle at.
You should be just fine.
If it STILL fails......then we have some hunting to do.......but you should be ok.
Also notice that the RPM's that the test was done at....seems kinda low....hopefully he isn't doing the test in OD........would explain why the NOx is a bit on the elevated side.
Old Oct 18, 2002 | 10:48 PM
CARdiac's Avatar
Wish me luck, tomorrow I will drive on the Hwy for at least a half hour then I will go to a new shop......if I don't pass I am screwed
Old Oct 19, 2002 | 10:26 AM
.....you won't be screwed...........we'll just have to have another plan of attacK
......remember.......DON'T SHUT IT OFF!!!!!!!!!!!!
Old Oct 19, 2002 | 05:57 PM
CARdiac's Avatar
I FRIGGIN PASSED!!!!!!!!!!!
Spent 45 minutes on the highway in D (not OD) w/ the rpms at 2500, went to the shop and friggin passed!
My numbers:
High Speed*************************Low
HC**********117*******************91
CO**********0.17******************0.55
NOx*********737*******************793
Thanks a bunch...btw, where I took it today kept the RPMs up and was willing to "help" if I didn't pass!!!
Old Oct 20, 2002 | 04:52 AM
Congrats buddy.
The tech doing the test can make all the difference in the world.
.......told ya you nothing to worry about.......
Old Oct 20, 2002 | 06:52 PM
ibanez6rg's Avatar
Hell Yeah!!!
