V6 vs V8 springs Interchangeable???
Old Oct 20, 2002 | 09:05 PM
Mikael's Avatar
I was wondering, since there are a few of you doing LT1 swaps, are they interchangable? I know the spring rates are different, but what about the actual fit?
Mike
Old Oct 20, 2002 | 10:40 PM
stars1010's Avatar
I cant say from experience, but as far as I know they are totally interchangeable. Should be same exact fit.
Old Oct 21, 2002 | 12:33 AM
atl2001's Avatar
From: carbondale IL \ Alton IL (outside St Louie MO)
ill let you know when i put mine on, i have been told they fit , i have a set , just arent on yet
Old Oct 21, 2002 | 09:19 AM
MustangEater82's Avatar
They ar totally interchangeable, same withabout every other suspension part.
thing is they will raise the front of the car an inch or two do to the lighter weight of a v6.
Old Oct 21, 2002 | 10:51 AM
Mikael's Avatar
I actually have a V8, but i couldn't get a response in LT1 tech. You guys are alright.
Mike
Old Oct 24, 2002 | 10:19 PM
stagen's Avatar
Completely inter-changeable with no modifications needed to be done.
In fact you'll see some fo the LT1 guys running rear V6 springs at the track.
Old Oct 26, 2002 | 09:39 PM
FilledWithFurySS's Avatar
yes they are interchangable...
Good luck in the swap!!
~Mike
Old Oct 27, 2002 | 01:40 AM
blue95's Avatar
yup they will go and they are a small upgrade for our cars(depending on the year)....check out this page for some specs on them
http://angelfire.com/my/fastcar/suspension.html
9t4lt4z28
Parts Wanted
Jul 19, 2015 06:16 PM
Catmaigne
Jul 14, 2015 05:17 PM
8bit
Jun 29, 2015 02:38 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
