SLP Differential
Old Oct 16, 2002 | 07:33 PM
nexus77241's Avatar
SLP Differential
I am really p'od because I royally spun out today in the bad weather today (and nearly crashed ), so I am going to get the differential. When I get the differential, for my 99 Firebird, what other parts do I need and about how much does it cost to get installed? thanks.
Old Oct 17, 2002 | 05:18 PM
bowtieracer6's Avatar
I bought mine and took it to a gear shop. He istalled it for like $150 and on the reciept the only other parts he listed was a shim package and some gear oil. Hope that helps, its a great mod.
Old Oct 17, 2002 | 06:34 PM
nikkev's Avatar
It should cost absolutely nothing!Do it yourself in the driveway.All you need is common hand tools,a jack and jackstands,gear oil, and GM limited slip additive.Check out this link:
http://www.fastblackcar.com/camaro/lsd.htm
It's what I used to instal a posi in my '95.It was the first major mod I had done and it only took like 2 hours.Good luck.
Kevin
Old Oct 18, 2002 | 12:29 AM
Scammper's Avatar
Question
I have gone back and forth on the Posi thing. I really like the idea of posi... but Im still not sure my 3.4 has enough power to make it worth it...
I also hear that it can damage other things, drive shaft, etc...
any thoughts or facts that might help me make up my mind on this issue??
Old Oct 18, 2002 | 05:20 PM
nikkev's Avatar
Nope,no damage.I could still spin 2nd gear in my 1995 3.4 A4 (with a Trans-go).The best thing about the posi is that it gets rid of a LOT of wheel spin and lets you just squat and GO while the other guy's still trying to get traction.Good luck.
Kevin
G-BODYT56
Jan 14, 2022 11:14 PM
n2oblkz
Oct 12, 2015 01:53 AM
sahlomonic
Parts Wanted
Sep 22, 2015 03:13 PM
tommalcolm
Sep 11, 2015 03:39 PM
rideordie
Sep 7, 2015 08:22 AM
