View Full Version : V6 Tech
- the whisper lid intake?????
- Block off for EGR passage
- Ses Help!!
- dynoed the beast
- Can anyone run a carfax for me?
- Driveshaft swap
- 3800 SC to 4l60E
- Movin on up!!
- Catalytic Converter?
- Jet stage 2 chip
- Urgent!! Fuel Pump
- damn noises, what about this one?
- exhaust
- Stealth Airbox
- trans am airbox to fit?
- TB spacer?
- Ive got a problem..
- Car doesent powerbrake!
- Front Bumper
- V6 to V8 conversion guide?
- Turbo set up, dead end (grrrrr)
- Synthetic oil for my '94 V6?
- I need to know wich muffler to get
- Technical: Bore and Stroke
- vibrations while braking
- new site
- '95 V-6 w/5-speed to T-56?
- Scu2000
- dyno'd the setup today..
- orders at tbyrnesports.com
- Need help!
- power loss
- dimming lights
- tough choice?? i need advice...
- fuel injectors???
- 3.4L + 272cam +22lb.hr. + 2.8 intake
- new pics...
- Ok. Going to replace exhaust piping.
- Does taking out the airfilter help any at the track?
- Ram Air question
- Anybody have Superchip, JET chip, or any other PCM?
- Painting Calipers!!!
- Alternator question?
- Is someone under my car?
- Engine Light
- Restrictive exhaust?
- How can I protect my plug wires?
- oil change
- Ticking noise
- Transgo Shift kit worth it?
- air lid
- which chip??
- V6 vs. Hummer H2
- Visage underbody kit.
- need sound clip of 80 series at REDLINE
- 3.8 engine problems please help????
- Tachometer help
- Superchip or 2.5 inch piping?
- SECURITY light stays on??Help!!
- Not Home, Can Someone Check This For Me?
- 3.4 performance
- Auto to Manual
- what is the stock o2 sensor GM part #?
- V6 Exhaust
- Headlights brighter?
- GM 97-03 3.4L aluminum heads?
- 2.8 to 3.4 w/ big ulgy cam, swap
- exhaust questions
- 40 series flowmaster
- Exhaust Sound clips
- Any Tips??
- Exhaust width
- help changing head gasket
- Need to borrow Y87 VIN
- Well guys, Im gonna have to say goodbye!
- Gauges
- gears (yes i read the other posts)
- V6 to Y87
- i need sound clips!!!
- What temp does your gage normally read?
- Where is the coolant drain plug for engine?
- spring updates
- HP estimates???
- Best Oil Change
- free ram air Q's
- exhaust installation Q's
- 3.4 to 5.7
- Noise comming from rear end
- price check
- 1997 Camaro VIN...
- what's it gonna cost for juice?
- New Club looking for Members
- y2k corvette rims
- Cat Replacement
- where can i find a 3.4 v6 engine?
- replace fuel pump?
- quick lt1 swap question
- muffler back
- Fuel Pump Q??
- my induction sys
- transmission question
- What exhaust system is good for a 3.4L?
- pro 5.0
- V6 mods
- Just installed my Flowmaster Catback #17356
- my frustraiting car
- model paint??????????
- Venom??
- Got my twin turbos installed, and SC on my other car, widescreen pics inside
- catalytic convertor smells?
- V6s and exhaust cutouts
- Transmission mount?
- 0-60 times on v6
- Dynomouth???
- Life of the timing chain?
- Modifications
- Finally finished the clutch
- Is this a good stock quarter time?
- what intake do you have?
- Re-tightening header bolts
- urgent!!!!!!
- Transmission question
- Intake Question
- What should I do????
- Exhaust
- cut-out on v6
- what is wrong with my car?? need advice..
- my 98 vs. 88 Iroc Z
- Torque specs
- New pics
- only 48000 miles and this...
- 2.25 in to 2.5?
- inlet outlet
- Flowtech muffler on a 3.8
- rear end+tranny
- Cam + 1.8 Roller Rockers
- V6 have more Hp than Z28 ha ha
- Catback Exhaust
- intake question....
- 1FastV6...good news
- Beat Me
- TB Plate for NOS
- weight diff?
- Edited my cardomain today
- dual exhaust????
- EGR block off mod?
- AC tune up?
- Cabin Air Filters?
- 95 Camaro 3.4L and the SES light...
- Intake
- Clutch install
- finaly somewhat better pics
- what do you guys think?
- Anyone lookin' for a 95 3.4L M5 HPP?
- SES diagnostics help
- 3.8L Intake Manifold Bolt Torque Sequence
- 93 V6 ... what is this plug on the driver side head?
- 98 v6 to lt4
- My Car vs. Honda Prelude
- Brake Rotors
- cam gears and supercharger Q's
- englishtown dragstrip
- help needed with thermostat/rough idle
- A dumb question what a 93-97 bolt pattern
- What plenum is the best?
- Power max 3.4
- egr?
- camaro pics
- Mass air Flow, Ram air hood?
- Went to the track last night
- Obdii??
- 3.4L intake?
- Z28 Rearend on V6?
- Z28 Throttle Body on 3.4
- Easy or Hard to install Shift kit??
- What kind of Oil Pressure do ya'll have?
- Moving to MO....Anyone live out that way?
- Window Motors
- trans question for future
- Post your 0-60 times!
- Drop shipped? what does that mean?
- 1995 3.4l V6 A4
- few q's on trashed tranny/clutch...
- Service Engine Soon
- steel wheels
- 3.73s in v6
- Where do I find a dynomax catback????
- custom GMMG?
- 96 Firebird leaking coolant
- Going to the Track this weekend..lets Guess what i will run:)
- Alternator is poop; What's a good alternator brand?
- top speed govenor
- beefy 3.4 cam???
- Gears Please Help Me!!
- 3.8 Borla Exhaust w/Comp Cam Sounds?
- What engine should I get?
- putting chrome tips on exhaust
- gears
- Best place to buy V6 cams
- 3.4 to LS1 Swap
- Door Swap
- okay guys...helped me out in past...see what u can do with this one
- pro kit/ bilstein install help
- Help with seafoam please.
- What size should i buy???
- What gears do i have??
- high idle...again
- which exhaust should i get
- fog lights
- T-Top Conversion
- Need to do a part cross reference
- SLP "Loudmouth" on a 98 3.8
- 350 crate motor
- Need new cat. converter
- Will LS1 Drop Springs be same height in a V6?
- dual exhaust
- What's a torque converter and does it help?
- what shifter should i get
- Whats Better??
- 97 3.8L Performance Chip??
- 3.4 L Pacesetter headers....
- Engine Swap Help
- high idleing
- springs, what to get for 02 v6
- bad vibration need help
- Installing 3.8L catback kit
- clear front plate cover
- Need help w/ Headers/true dual/pipe size
- stock v6 springs
- Bleeding Brake System for Bird with Traction Control
- Homemade Ram air system
- Changing serpentine belt
- 245/60/16 on Salad Shooters
- 3.42 vs. 3.73 in an A4
- how to install rear shocks....
- Torque Converter...Please Help
- swap idea 4 u guys
- Exhaust Question
- What Times/Speeds do you V6's get
- Rollers 1.8
- Will Z28 tips go on my Y87 Muffler?
- cheapest?
- 95 camaro
- blown head gasket? long>>
- Leak near water pump. HELP pls!
- Need some help on a part #
- V6 Conversion
- lids
