PDA
View Full Version : V6 Tech
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23
  1. Is my coolent right?
  2. 1994 v6 to carb 383
  3. wont start...
  4. Heater Core?
  5. y87 Camaro Muffler
  6. 1996 posi??
  7. Plug wires
  8. Is it worth modding my v6?
  9. Pics of my engine.. Is it toast?
  10. superchargers...do they work???
  11. HEADERS for a 3.4L
  12. how to perk up a 2.8L
  13. 1998 Camaro V6?s
  14. Problem with 1999 SES light
  15. why is my abs light on?
  16. Cylinder Heads
  17. Please help identify this part
  18. Can rust from your radiator build up in your engine??
  19. Questions: MSD Ignition For 3800II
  20. Chevy V6 Needs Help- non camaro.
  21. What can I get for $500?
  22. Service Bulletin
  23. Call out to the 3.4L owners
  24. What is this that's leaking oil?
  25. Front main seal leak
  26. 3.4L engine replacement problem
  27. 3.8L MAF Forsale-Brand New
  28. no guage lights
  29. Car sputters
  30. For those who want 05 Mustang V6 times>
  31. Power Problem Is Back!!
  32. what do u guys think is the faster v6?
  33. I feel like I have some kind of intermitant miss during crusing
  34. Third gen programmer?
  35. what kind of gears do i have?
  36. 3.4 liter auto tranny fit
  37. Flowmaster 40 Vs. No Muffler
  38. 3.8 Turbo
  39. need help to find a part
  40. How do i remove fuel lines from intake????
  41. Fuel Pump Needed V6 Camaro
  42. Great V6 tires?
  43. Shift knob!!
  44. 1991 RS 3.1 Runs "Rich"
  45. okay, that was weird...
  46. Power problem
  47. major clutch problem
  48. wheres the fuel filter on our cars
  49. Low Oil Pressure???
  50. what kind of gas mileage are you 3.8 guys getting
  51. Intake manifold
  52. Anybody try the superchip or hypertech programmers on their car, how did they work
  53. Clutch Install
  54. fuel pump/wiring problem
  55. ECU programmer
  56. 3.4 cold start, really rough idle and rich..cat?
  57. will it be the same as it was?
  58. Considering switch to Valvoline Durablend, is it ok?
  59. mpg
  60. Noob question
  61. car wont run right?
  62. Cant even find front passenger side spark plug
  63. need help timing 4.3 CPI!!!
  64. powerdyne supercharger
  65. My 3.4 shakes when put in Drive
  66. Wierd squeeky sound?
  67. New Engine
  68. pass key system
  69. Fuel pressure test?
  70. Eaton m90 Supercharger
  71. 2000 V6 specs
  72. 1995 camaro
  73. Stumble under slight load
  74. V6 to LT1 swap, can I reuse V6 k member????
  75. 94 firebird 3.4 1/4 time and mpg
  76. steering wheel shakes left and right, car goes to the right
  77. Help with 2000 Camaro 3800
  78. Fuel leak, wont start
  79. 97 v6 same as 98 v6?
  80. my NA 3.8 camaro
  81. How much Nitrous..
  82. Mulsafied white oil??
  83. Flickering SES
  84. removing scratches...what can i say, im a perfectionist
  85. ignition module and testing
  86. First camaro
  87. Supercharging suggestions
  88. How much does it cost to convert a v6 to a v8?
  89. making christmas list!
  90. v6 horse numbers
  91. what gears?
  92. Engine Problems...Need Help, Backfiring + no power out of nowhere
  93. 3800 supercharged
  94. wtb!! wiring harness
  95. Spark plugs have a thinn white coating on them......whats that mean?
  96. 3.4 water pump
  97. Port and polish question
  98. Texas Speed V6 Tuning SPECIAL!!!
  99. 3.4L turbo kit for sale .....
  100. Gas mileage HELP!!!!!!!!!!!
  101. which rear controle arms
  102. Engine Swap (partial)
  103. Rattling Noise, goes away when you push cluth in, HELP
  104. Attention V6 to V8 swap guys
  105. new some help troubleshooting (massive misfire)
  106. Transmission Problem?!?
  107. Random Stall
  108. Good v6 sites?
  109. clutch install
  110. 5.0 TPI 305 into 94 camaro
  111. turbo?
  112. data logging
  113. What will i make with these..
  114. NO throttle at all, Just idles
  115. okay now I must be blind..
  116. 3.4 L Water pump question
  117. Someone please help a friend w/98 V6 motor prob
  118. Urgent help needed for CPS
  119. Strange jerking in cruise...
  120. what are the stock gears???
  121. Exhaust videos 3.8L w/loudmouth and 3.4L w/rumbler
  122. Anyone that can help with a 97' Grand Prix GT
  123. coolant temp question? help
  124. Bleeding the Slave Cylinder
  125. Fan Switch in place of Knock Sensor
  126. rearend gear question
  127. Did LT1 - What to do about fuel pump?
  128. Gas Tank Question
  129. TPS voltage
  130. Opinions on Clear image automotive headers.
  131. What can I do to add power to my Camaro?
  132. ABS Inop Light stuck on
  133. 3.4 wont start??
  134. Making my own spark plug wires?
  135. 95 3.4 Hard Start
  136. best shifter/ short stick combo for 3.4 5spd???
  137. Help Please!
  138. Just got my Best MPG EVER!
  139. Loss of power at mid-high rpm's
  140. how much
  141. throttle body p&p?
  142. do i need larger injectors
  143. 2003 rsx type s vs 2000 y87 firebird?
  144. Adjusting the clutch?
  145. wont shift 1-2 unless you let off gas?
  146. what kind of cat to buy.. 3.4
  147. Overheating! Help!
  148. Huge Bmr Sale
  149. What will the 3.8 fit into?
  150. Voltage Problems
  151. Loaded 1996 Camaro For Sale
  152. Did 3.4 to LT1 no start.
  153. My car is having trouble starting
  154. I just bought a 99' 3.8v6
  155. Length of Catco Converter?
  156. Shifter knob thread size
  157. best catback
  158. eCharger?????
  159. worth the money?
  160. cylinder head/ intake install
  161. 3.8L Wiring Diagrams?
  162. Intake runner design, short vs. long. w/pic!
  163. 13's N/A!
  164. Need a fuel pump for a 3.8L Camaro
  165. MAF - Code 34
  166. car problems
  167. heading to the strip
  168. Turbo Project
  169. gauge problems
  170. y does a grand national sound like an 8 and my car sounds like poop? is it the turbo?
  171. Mileage 3800 v6?
  172. Simple Question from a Newb
  173. Low Oil Pressure?
  174. supercharger 4 my bird
  175. Direct fit vs. Universal Cats
  176. will these mods put me into the 14's?
  177. repl. headgasket kit
  178. Nissan turbo in a camaro?
  179. HP Question?
  180. Install Power locks, windows & Key fob?
  181. my 2000 y87 firebird vs 95 neon r/t sport coupe. how did i lose???
  182. i think i screwed my engine with seafoam
  183. Torque Converter
  184. looking for help
  185. Boost and the 3.4
  186. Gasket options
  187. Yet another issue....
  188. Dirty Engine-Cleaning tips?
  189. Need help, am lost
  190. hey guys im back again
  191. Track results for friends 3.8 V6
  192. V6 muffler opinions
  193. Supercharger?
  194. 02 Camaro
  195. Cooling problems.
  196. Track times and dyno for the charged 3.4
  197. Throttle Body
  198. Oil Pressure
  199. car starting problems
  200. Bolt pattern for a V6 4l60E same as LT1 T56???
  201. Replacing Starter?
  202. blown head gasket
  203. Exhaust problem
  204. Electrical issue
  205. crooked steering wheel?????
  206. Car misfires all the time.
  207. Fuel injector cleaners?
  208. New 99 V6
  209. fluid changes
  210. What Hooker catback for my 97 V6?
  211. Turbo and charger kits?
  212. headlights wont pop up
  213. 2.8L swap to a V8....?
  214. LT1 Exhaust?
  215. Electrical Problems
  216. '95 3.4 camaro dies today
  217. Timing Belt or Timing Chain?
  218. Problem fixed *sputtering stalling hesitation*
  219. Distributor and coil replacement?
  220. ran over something now my cars nuts..
  221. 1/4 mile times
  222. Ignitions? MSD DIS 4, Dig 6+, 6AL.....
  223. Question on overdrive
  224. LT1 swap
  225. Working on new overlays--Multiple Color Options
  226. How to clean injectors?
  227. I need a oil pan
  228. need help, car all messed up
  229. Found a blower kit for 3.4L, $700
  230. noob questions (v6 to turbo/twin turbo)
  231. 3.4 V6 - SBC 350 Carbed
  232. Problem with my lights!
  233. Trying to find...
  234. A Few Questions
  235. leaking oil pan + changing rear drum shoes....
  236. V6 to V8 Will the 5 speed bolt up??
  237. What would cause a turn signal bulb to keep blowing up?
  238. Wierdest problem ever, ideas?
  239. Not starting after it sits
  240. Help msd dis-4
  241. Service engline light is on, reader said auxiliary emissions, what does that mean
  242. Injectors not firing
  243. Change in Shifting
  244. engine swap help
  245. Bad vibration from front right
  246. Should I run a Dynomax bullet w/flowmaster?
  247. How to change water pump??
  248. Please lord help me, the 85' dead, again.
  249. Dad's AC isn't running correctly
  250. Engine Kit
