View Full Version : V6 Tech
- Another Question
- V6 Driveshaft busted...again(?)
- modded v6 worth v8 ?
- Help! Car won't start!
- 3800SC prime oil pump
- Putting in Headers...
- Question??
- 1988 2.8 multiport
- places to fix f-bodys in San diego or Chula Vista
- Strange noise from dash board
- Heads?
- What can a 3.8L be swaped with?
- muffer mounting location and other exhaust questions
- Wires Arcing?
- HELP Problems whit Camaro 97
- any v6's with gears and posi upgrade??
- Need help, no experence with electronic motors
- Cheap/Good Code reader?
- Engine light
- 2 problems:
- U-joint Replacement
- 95 camaro...removing EGR?
- 94 V6 water pump replacement
- funny question for you guys
- 4.3 v6 vs v8
- Does the 3.4 require pcm tuning after ........
- BEST Ignition wires?
- What are the best bolt ons and Results
- throttle body
- 94 camaro 3.4 to 4.3 swap
- 3400 questions
- Fuel filter 2000 3.8L v6
- Headers?
- Ticking injectors
- Few 3.8 camaro questions
- venom 400 chip for 3.4l
- overheating question
- Some Coolent questions
- 1998 3.8 blown camaro... need information about swapping in another 3.8
- 97 camaro v6 running problems
- Turbo Exhaust Manifolds
- 1999 3.8L governor limited?
- Dash board conversion??
- 99 3800 ticking????
- K&n vs. SLP
- Upgrading V6
- HELP- Blown Engine
- holley fuel pressure regulator
- 1989 camaro injectors problem
- Difference between 96 3.8 and a 98 3.8???
- 350 carb in 95 camaro
- urgent car problems
- TOTALED! How much?
- brakestands with a V6?
- help 3.4 running bad
- Cam / Valvetrain
- HELP! 95 Camaro 3.4 L V6 EGR & gas loss problem
- 2001 3.8 performance musts. what to do?
- all kinds of problems...
- 3.4 Rebuild
- ACDelco plugs
- Black stuff
- Rod Diameter? 3.1
- How to adjust rockers on a 3.1? Need help!
- Exhaust Question
- master cylinder lines
- just ran a 12.0360 @ 112 in my V6
- Cold start problem...
- '95 3.4l Stock Tranny
- Trans filter for 2000 A4
- 3800 series 2 HP ??
- Overheating! Please Help Me (I've been going crazy with this)
- 3.8L trouble code
- How many miles on your V6?
- can I swap the 3800 series 2 out of my 97 camaro for 3800 series 3 supercharged
- Does LS1 driveshaft fit 2000 v6?
- 3400 to 3800 swap?
- new
- 3.1 sucks
- 1998 Cai
- Underdrive pulley...
- msd dis 4 help...
- which are teh best sites?
- 1997 Camaro RS 3.8L V6 mods... what can I do?
- 95 camaro 3.4 V6 Cold Air Intake
- A little help please..
- 12-13mpg in 3.4L
- Automatic to Manual
- needs upgrading
- What's the prob??? My gas guage goes up and down irratically.
- PCM Programming for 3.8L
- 3.4 to 3.8 questions
- engine will not turn over
- ??Car has loss of power on both bottom and top end, it hesitates, vibrates, shudders.
- ls1 swap no start
- power steering pump
- 3.4L What are symptoms of bad Crank Position Sensor?
- B&M Ripper Question
- manual trans issues 96 3800
- Pics of rusty drivetrain & VIDEO of engine, weird skip.need advice!
- False Misfire Code?
- Removing EGR on a 3.4
- 3800 rebuild
- fuel ,wont start.
- I put in a bigger radiator.
- Keyless entry programming
- Nevermind Previous Thread I Posted
- questions about v6-LS1 conversion
- Mileage worth it?
- Selling your camaro?
- WTF is going on?
- What size gas tank?
- missfire only in overdrive
- Shed some pounds off that maro!
- Multiple Misfire help
- Camaros?
- Alternator for a 3.4 help!!
- Buying an MSD DIS 4 - questions
- Underbody Rust
- Flowmaster!
- Sway bar size
- 97 3.8 liter v6 idling problems
- Picking up a 1994 with a 3.4... are they good? Have questions
- 3.8 Header Bolts
- muffler
- Best intake for a V6
- Oil pan on a sixer
- track times
- tires
- hesitation and misfire on 94 3.4L
- Ticking from driver side of 96 camaro
- Short Shifter
- Misfire on 1995 3.4L V6 Camaro
- 3.4l 1995 with obd2 computer need best ch
- platinum plugs
- Venom 400??
- Big problems with crank senser(HELP)
- 97 3.8L not starting?
- Just like new?
- 3.4l upgrades
- Old Car, New Possibilities
- Used Injectors.. Tips?
- Water in oil maybe??? Pics inside....
- Can you do this in California and get away with it?
- the best chip for a semi-modified camaro (obd2)
- tune up on a 97 firebird
- v6 to v8 swap, opinions plz
- 95 3.4l to 350
- what size freese plug
- pulleys
- freeze plug ?
- 01 missfire
- O2 simulators. where to get em...
- 98+ crank pulley
- Good first mods
- Pls Help Me Someone!!!!
- 95-02 3.8 coil packs
- Look at this pic and tell me if you see a 3800 pilot bushing.
- cold air intake
- oilconsumption
- v6 stuff on ebay cheap
- engine swap idea
- New plugs/wires, still have misfire
- will a computer chip make a diff?
- will a firebird?
- 3.8 pushrod
- new parts for a 3.8
- possible exhaust manifold leak? need help!
- Engine code.
- 97 V6 trouble starting???
- Strange brakelight prob, help!
- tranny swap
- Anyone have some front V6 springs
- 1994 3.4 V6 vibrates
- Smithy's Patriot mufflers
- Pacesetter exhaust headers...good? no good? please respond asap
- Well I am needing info on what Chip to install...if I can even get one...
- Whats It Worth?
- ported heads
- distrutorless 3.4
- oh damn it!!
- Forced Induction?
- Ok, new q for you guys... Head Gaskets
- Wiring question for any V6 owner.
- What would happen if I removed my Cat when installing my flowmaster CAT back?
- v6 to v8 Lt1?
- Codes and O2 reading
- Wires burning? help...
- asr in 3.4??????
- Cam info
- cooling system question
- plugs and wires?
- 3.4l?
- GM Tech's - Injector ?
- P1406 DTC code question
- Crank car but engine is locked (hangs) until about 10th try.
- misfire...again
- Gas Mileage
- convertbile problem
- which type of oil would be best for my car?
- cold start noise
- starting problem
- torque question
- headers...
- freeze plugs???
- What temp do fans kick on?
- Code P0175
- broken vacuum line
- After Market Shifter
- Help me get a 1998 Camaro stand out some..
- Swapping a v6 to a v8
- Temp gage on 93
- egr removal?????
- Weird sound during cold start up.
- spark plug installation
- Fuel pump
- 3.4L Intake Manifold Gaskets
- 3.4 horsepower increase
- question about catalytic converter on 1997 V6
- Technical Info
- Pulled a tire off the ground..... N/A
- Corvette or SS?
- Weird Injector problem w/ my friends car.
- how to pull codes on 94 3.4, mouse ate thru wires!
- 3.1 V6 oil leaks?
- Got some pretty impressive MPG!!!
- air doesn't blow out front vents
- Help, my Camaro went nuts last night
- Ignition Coils......Stock,MSD, or Accel?
- headlight switch?
- something is wrong with my 2000 firebird
- fuel rail fitting parts search
- Upgrading the fuel injectors
- f41?
- Y87 package
- Stock 3.4L Y-pipe double-walled? rattling...
- Tuned her up........and she pings?
- Heating Problems - '95... I need Help!
- difference between 96 v-6 camaro's and 98+
- V6 3.8 supercharged VS LT1 !
- Firebird V6 Cat converter delete
- shifting technique
- whats the difference between 96-97 3.8 and 98+
- Misfire and engine stall...
- ? about times
- AC Delco Rapidfires....Which #?
- Tune up....Needs some parts advice
- New best
- Catalyc Converter
- crappy belt tensioner!
