- seatbelt guides
- Exhaust question...yes another one
- can i chip my 98 V6?
- intake
- springs
- Some Car Troubles
- Magnaflow...quick question
- 3.4L upgrade suggestions! Help!
- need help finding supercharger or turbo
- supercharger
- oil level
- need help/advise on selling my V6
- Which Tires?
- Rearend noise
- Where can I get 3.4L timing gears?
- electrical problem after rain
- 3 questions
- Engine Swapping Question - V6 vs. V8
- Urgent Help
- new 3.4 owner with questions...
- looking for numbers. . .
- 3.4 V6 Throttle position sensor
- V8 Shocks
- Dude at work's gotta V6...
- Quick ?? for you 2000 Automatic guys
- cheapest way for posi
- Clutch question
- 2.8/3.1 Rejoice
- cold air, lid. 96 camaro??
- Flowmasters on a V6?
- Need help picking a muffler
- upgrade your v-6
- SLP 1.8 rocker arm GP
- brakes and rotors question
- Service Engine Light Question?
- Rear main seal?
- Valve Cover Question
- Turbo 3.4l...
- auto gears in manual
- Plentum spacer
- door swap? 94 doors to a 99
- Volant Intake
- grand national motor in a 96 f body
- Hypertech Programmer?
- LOUD Squeaking from belts....won't go away!!
- I need some help with my AC
- Turbos on a 3.4?????
- 1997 Camaro 3.8 V6
- 97 V6 Tranny probs. Please help!
- Noise with slight miss
- anyone need an extra 3.4 (engine only)...take a look
- Flowmaster 40 Series?
- everyone with a 96 3.8 please reply
- POST 1/8 and 1/4 times here
- torque specs for 95' water pump.
- Buddy Help
- Does anyone else have a rattling noise?
- new camaro owner needs help
- ABS/brake problems
- blower off of a gtp on a 2000 rs?
- Magnaflow exhaust
- will this fit?
- MSD- some answers needed
- Do I need GM additive?
- V6 Dual Exhaust
- quick questions from a new owner
- Intake Air Temperature Sensor
- v6 with twin turbo???
- Need help, Engine pics
- Mpg
- Uneven brake pad wear
- New Pics.
- Question on what years have what Gauge Clusters and ABS.
- People with 255/50-16's come on in...
- hav'n trouble...
- such thing as a formula v6???
- maybee a rebuild?
- Some goofy electrical/ECM problems...
- rear end gears for turbo 3.4L
- Die Die Die Camaro
- How can I fix my speedo/odo?
- roller rockers
- faster v6 camaro
- A/C Vents not working
- what i'm looking for
- Clutch question
- Adjusting the clutch
- Will someone please help me out, i need pics of a 96 3.8 engine to see vaccuum lines
- 1/8 to 1/4 times
- new here with a problem....
- No Fire Help!
- widest tires on 18 inch rims
- RR help ASAP
- 336 rwhp and 397rwtq video inside
- CAT removal? Cut-outs?
- New Member, New(used) Car, New Question!
- Best Exhaust for 3.4
- A/C help
- Exhaust systems???
- LS6 swap?
- Wires from a 93 T/A in a 97 Camaro
- need help please
- finally some decent numbers from teh beast....
- what is this thing?
- Radiator is leaking
- help needed with intake sensor mod
- v6 2 ls1 swap
- help please
- 3.8 max torque numbers
- What's a good oil leak stopper additive?
- loss of power in low rpms??
- Want '01 Z28 wheels & tires?
- idle fluctuation when first starting up
- Need Help from 3.4 V6 Owner's :(
- removed cat
- 2000 Camaro keeps popping front left turn signal bulbs..
- Rs
- JET modules
- Whisper lid questions
- Cutout on a 3.8l?
- How can I tell???
- Biggest bag for the buck addon
- SPEC Clutches and thoughts about:
- Exhaust Cutouts
- Question re: '01 Camaro
- quick ?
- Stupid Headlights Question.
- A couple of Q's
- Congrats to Max!!!!!
- rant: follow up to previous post...
- Tranny Swap
- check engine light
- Nx Wet Kit 20920....help Fast!!!
- 95 Firebird in Parts
- What do I have to do for a V8 conversion?
- need help with crazy problems!!!
- MSD Digital 6 Ignition
- SLP 1.8 Roller Rocker Package
- How to remove passenger side lift bracket
- amber turn signals
- anyone running msd wires?
- oil filter
- Advise on buying a camaro
- drop a gtp into a 3.8???
- crazy steering wheel!!
- Anyone looking for a new motor?
- 96 camaro CAI
- A/C not cold & hissing sound in vents from A/C?
- Help...acceleration issues...
- exhaust smoke and back fire
- squealing front brakes....need help
- power mirror conversion
- oil change
- Wher to buy? -After Market Parts
- V8 exhaust on a V6
- extreme loss of power...thinking tranny
- cam install?
- anyone ever have a timing belt/chain go?
- GTP body control module Problem
- Nitrous Kit
- Hazard lights coming on and both wheels....
- Best Ways To Add Some Quick Horse Power
- manual fan switch
- Keyless entry problem
- recommended mods
- Will this make a ricey sound??
- HELP!! Important Fan ????????~!~!~!
- Cat on exhaust smoking! HELP
- 3.4 liter heads...
- 96 chips/reprogrammers for 3.8
- What headers for 02 V6 Camaro?
- Oil change and gas gauge
- How to get stripped Screw off?
- Autometer Gauge Install
- Cuting out problem at 3500 rpm
- Pacesetter headers
- cam?
- Best sounding exhaust for a v6?
- eibach sportlines on a V6??
- JET pulleys stress me out! Need part#
- slight hesistation under initial load, pls help :)
- SLP shift knob
- WTF idle air HELP
- serpentine belt
- 3.4 Pacesetter headers
- Pulleys
- Chips
- Backfire through intake!!
- Exhaust question for a friend
- Acceleration problem in heavy rain..?
- Fog lamp bulbs
- Flowmaster exhaust system for 3.4l
- please help! thanks
- Please Help!!
- Help!! I hsve starting and idle problems
- Surge w/SES light
- 5speed gear ratios.
- V6 or V8 For First F-Bod
- Best catalytic converters?
- best clutch to get?
- Shift Points
- CAI on ebay?
- i think i have a problem
- Best Exhaust setup?
- Best induction setup?
- Cam for 96 3.8 liter?
- 3.8 engine mods
- vortech supercharger
- CAI for 99 V6
- intercooler
- Transmission RPO codes
- Why get a lid?
- 96' V6 Revving Problem....!?
- Gear question
- Need Confirmation of 2000+ V6 auto's.. experts inside
- **Urgent help please**
- VISA tires (a.k.a. Falken tires)
- Not sure what to do.....
- How much should exhaust installation cost?
- 95 3.4 Code reader?
- My sound system cracked my dash!!!
- Dad Broke My Parking Brake
- performance chip
- 1996 3.8 Starting Problem
- Question about stock diff. gear and upgrade
- engine conversion
- wanted, 3.8
- best bang for under $500
- Ram Air Mod vs SLP intake
- 3.4l vs 3.8l
- Best 3.8 Engine Mods?
- pictures of moda r6 wheels anyone?
- someone explain this!
- SES light
- who has the highest mileage 3.8?
- Where to get Accel Coils?
- Muffler Size?
- changing v6 spark plugs....passenger side
- 3.8 vs 3.8
- help asap
- Help with cylinder heads
- Will an LT1 fit into my 94 firebird I'm replacing a 3.4 V6?
- Will this catch on fire?
- Which is quieter?
- scoop for cai under the car?
- A4 sliping? Need help A.S.A.P.
- dyno results
- 93-95 camaro now or 96 camaro and wait
- Good Deal?
- 94 V8 FIPK for 95 3.8
