getting sick of 3.4 :)
Old Oct 11, 2002 | 05:29 PM
PitySister's Avatar
if i do any more mods....i'll be adding 3.42's and lsd in the spring....but is it really going to wake up the car that much....just recently drove my friends VW 1.8t, and realized it handed my car it's own ***.....just kinda depressed
so is it worth the $730 + to get the gears in....
Old Oct 11, 2002 | 06:32 PM
94CaliCamaro's Avatar
Don't bother fixing up the 3.4, if you really want power then go for a turbo or some nitrous if speed is what you're looking for. Otherwise it is a bunch of money you'll be wasting. The money you'd spend on those gears would be little gain. Save your money and get an LT1 or LS1.
Old Oct 11, 2002 | 08:52 PM
MustangEater82's Avatar
$730 for gears!?!?!?!
not worth that much
I aid $408 shipped and got 3.42s, lsd, and 4-wheel disc brakes and the main reason i did this was my stock diffy was leaking and my gears were trashed, and I had broken a wheel lug. So I was looking to replace alot of stuff it was cheaper to upgrade.
Old Oct 11, 2002 | 08:54 PM
nikkev's Avatar
Cool
I personally wouldn't get gears since you already have 3.23's.A posi would be a very good idea though at only $100.Also you can install a posi yourself in the driveway.The 3.4 is a great motor,don't listen to the guys who say to ditch it.Also don't go by butt-meter feelings.My old 3.4 felt stronger off the line than my 1998 Z and we all know which one is actually faster.Good luck and enjoy the ride.
Kevin
Old Oct 11, 2002 | 09:58 PM
Kevin
3.4L of course...
If you are really unhappy with the car sell it and get a VW with a 1.8T, its gonna cost ya though.
Old Oct 12, 2002 | 01:09 AM
PitySister's Avatar
prices based on the slp kit from tbyrne....includes gears, lsd, and speedometer recalibrator.....
i thought somebody said the 3.4 came with 2.73's stock? i musta been confused
i could really use better gas mileage....and having a 4 cyl on the insurance wouldn't be bad at all....i'll be debating on this awhile....
but are the 3.42's and lsd going to help me out all that much....i'm not totally giving up on the camaro
Old Oct 12, 2002 | 01:15 AM
nikkev's Avatar
No,the 3.42's will not help that much,but the posi will.It'll make the care feel different when driving and you'll launch like a bat outa hell.All 3.4's came with 3.23's stock as far as I know.One way to be absolutely sure is to look for the code GU5 on the door sticker or glove box sticker.Also I don't think that the 4 banger will get better gas mileage.My old 3.4 used to get 33 mpg on highway trips.I doubt you'll get much better than that with the 4 banger.Good luck with the car or the sale,either way.If you are unhappy with the car for whatever reason then I say get rid of it.
Kevin
Old Oct 12, 2002 | 11:08 AM
V6 Punk 93's Avatar
VW = girl car
Old Oct 12, 2002 | 12:35 PM
PitySister's Avatar
Kevin
i get 16 mpg in the city.....and not much more on the highway....
thanks for the helpful advice you always give nikkev.....where to find a posi for $100....and how to install it?
Old Oct 12, 2002 | 01:45 PM
nikkev's Avatar
Cool
How long since your last tune-up?How about since your last wheel alignment?Do you run 33psi in the tires?All of those things and more will affect your gas mileage.The major one is the tune-up though.If your car has higher miles then I would suggest spending the 30 bucks for new O2 sensors and swapping them out.If they are a little messed up then not only will you get better mileage,but your car will feel like you gained some power.As far as the posi goes,I bought mine from SLP but I can't remember their website Anyway,they are also all over E-bay:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1867118112
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1868184967
And here's even an entire rear with 3.42's and posi already installed:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1866087662
And here is the install page I used to install my posi.Keep in mind it was the first major thing I had done to the car and I still pulled it off!
http://www.fastblackcar.com/camaro/lsd.htm
Good luck and I hope I've helped.
Kevin
Old Oct 12, 2002 | 02:34 PM
PitySister's Avatar
i've got the new 02 sensors just waiting to get them in....getting a new hood put on my car, should have it back monday.....that's when they'll go in....been awhile since a tune up....and all my tires are usually kept around 30 psi....
thanks again for the info...you're always a big help...
Old Oct 12, 2002 | 03:15 PM
nikkev's Avatar
Anytime But how'd you know I need to lose weight??!!
Kevin
Old Oct 12, 2002 | 06:06 PM
PitySister's Avatar
Kevin
hehe...sorry....
tried getting sensors off today....wouldn't freaking budge....not a lot of room in there to work with either....boy that was fun....next step...see if shop can get them off
Old Oct 12, 2002 | 07:27 PM
nikkev's Avatar
Cool
Just kidding,I'm not fat,just in a silly mood.Try soaking the O2's down with WD-40 and letting it sit for a couple of hours.Most auto parts stores sell an O2 socket that helps a LOT.I think it's like $2 or something.Also try removing them with the engine slightly warm,that seems to help also.Good luck.
Kevin
Old Oct 12, 2002 | 07:56 PM
PitySister's Avatar
yeah i got the 02 socket....$10.....i took it in the *** on that one did soak it with wd-40....might go back in a bit and try it out....i soaked it a good 5 times with the wd....and i will try it with the engine warm....thanks for the tips....****ers better come off
