Drum Brakes
Old Oct 6, 2002 | 11:24 AM
V6pwrhouse's Avatar
Question Drum Brakes
Can someone explain how to replace the pads?
Old Oct 6, 2002 | 11:59 AM
nikkev's Avatar
Lightbulb
The best advice I can give you is this.Do not apply the E-brake!Jack up the rear of your car and put it on jackstands.Then take off both rear wheels so you have access to the brakes.Now,only do 1 side of the brakes at a time!!! That way,you'll be able to see how they go back together.Now,take off both drums by prying on them with a screwdriver.You may have to have a hammer help persuade them to come off also Now just choose which side you want to do first and take the pads off.I can't remember exactly how they go together,sorry.So you'll just have to pull one off and use the other side to see how to put it back together.Then after that one's working again,do the other side.Good luck.
Kevin
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
cohopefull
Sep 8, 2015 03:22 PM
maverickmk
Sep 1, 2015 09:17 PM
