clutch master cylinder help!!!!!!!!
Old Feb 10, 2004 | 05:24 PM
cwcamaro91's Avatar
I have a 1991 Camaro RS auto w/ overdrive. I am in the proccess of installing a 5-speed. I have the clutch/brake pedal assembly already installed. I am trying to find out where exactly I cut the hole for the master cylinder, so I can connect it to the clutch pedal, or if anyone has pictures, that would be helpful too. Thanx
Old Feb 10, 2004 | 07:32 PM
will62085's Avatar
if your car has insulation in it, the insulation will have the holes punched in it for the clutch master cylinder, just punch out the holes in the insulation, lay it back on the firewall, and trace it. thats what i did when i converted my '85 camaro. there is a great write up on this conversion here:
http://www.thirdgenresource.com/auto...ual_conversion
Old Feb 10, 2004 | 07:42 PM
cwcamaro91's Avatar
Thanx for the help, unfortunatly The linning got ripped when i was removing the brake pedal assyembly
Anyother suggestions?
Old Feb 10, 2004 | 07:51 PM
cwcamaro91's Avatar
Success!!!!!!!!!!!!!!
Even though it was tore out, i was able to put it back together....Thanx for the help
Old Feb 10, 2004 | 08:36 PM
will62085's Avatar
glad i could help ohh and by the way, welcome to the board!
sleeperZ96BT
Sep 9, 2015 08:28 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
karpetcm
Aug 14, 2015 03:02 PM
Aug 7, 2015 08:52 AM
NewsBot
Jul 8, 2015 06:47 PM
