Too many tranny coolers to choose from
Old Feb 11, 2004 | 01:06 AM
speedracer93z28's Avatar
i want my tranny to stay nice and cool, im gonna put in a 3000 stall soon. please help me get a good cooler that will fit nicely and work like no other. and do i really need a tranny temp gauge with this setup? thanks
Old Feb 11, 2004 | 04:23 AM
rskrause's Avatar
Moderator
I like the B&M "Hi-Tek" cooler pictured here http://www.bmracing.com/products/acc...iTekCooler.jpg The small size and integral fan gives you a lot of options as to where to mount it and it is very effective. No, I don't think you need a tranny temp gauge.
Rich Krause
Old Feb 11, 2004 | 06:10 PM
"White Knight"'s Avatar
I was wondering something similar. How is the electric fan hooked up? Is it temp activated, always running, or switch? I am going need a good one too----good post,
Where are these usually mounted? In front of radiator? Do you drill--or is it straps?
Old Feb 11, 2004 | 09:17 PM
rskrause's Avatar
Moderator
There is a 160 degree thermostat. Works great - with nearly 900hp in my 4,000lb car with a 4,200 stall I never see more than 195 degrees at the end of a 1/4m pass. never gets near that hot on the street. Mine is mounted horizontally under the passenger side headlight. Used the mounting tabs on the cooler.
Rich
Old Feb 11, 2004 | 11:03 PM
Perma-Cool makes a similar fan-assisted cooler.... Sounds like mine is mounted like Rich's, but on the drivers side.
Old Feb 12, 2004 | 02:42 PM
Is that picture from the bottom? So it's parallel with with the ground?
With the mounting tabs do u use zip ties?--I remember hearing that from somone once. Are those Zip ties in the picture Injuneer? I just don't want to be drilling holes in my baby
Mikes 1994 z28
Oct 10, 2015 07:55 AM
68camaroboltz
Oct 5, 2015 01:46 PM
Bxlt1
Sep 29, 2015 03:18 PM
