Which flexplate do I need?
Old Feb 29, 2004 | 08:18 PM
n2oCamaro's Avatar
I am trying to pick out a flexplate for my internal balance 383 with built 4l60e. I am not sure what is the correct one to get. I know its a 153 tooth, internal balance, but unsure of the converter bolt pattern. Is the LT1 4l60e converter bolt pattern the same as a th350? Also, which ARP converter bolts do I use? Thanks for any input!
Old Mar 1, 2004 | 06:43 AM
n2oCamaro's Avatar
ttt
Old Mar 1, 2004 | 02:09 PM
SteveC's Avatar
From: Poway CA, where GOD and the sun always shines
Try this sight and scroll past the PI torque converter, it will show you a picture of the TCI flexplate, and give the appropriate part number:
http://www.thunderracing.com/index.c...ategoryid=1081
SteveC
Old Mar 1, 2004 | 07:10 PM
n2oCamaro's Avatar
Thats for LS1. The 4l60e for the LS1 is different than the LT1. Thunder Racing is one of the first places I looked. For some reason they do not list a flexplate for LT1.
Old Mar 2, 2004 | 11:49 AM
fastcamz28's Avatar
I just received a new SFI approved 153 tooth flex plate from Jeg's for my '94 z28 w/ a high performance 4L60E. It's externally balanced (which is supposed to be the same as oem) and is the right unit according to my engine builder. This will go in a 383 (externally balanced) that's in progress. I believe you need a neutrally balanced flex plate if your 383 is internally balanced. I did not find an internally balanced flex plate when doing my search. Not sure about bolt pattern for a TH350 being the same and the ARP bolts. Hope this helps!
RUENUF
Mar 13, 2016 03:37 PM
alphaauto
Jul 26, 2015 04:40 PM
vodoo-chile
Nov 13, 2003 01:31 PM
vodoo-chile
Nov 11, 2003 08:56 AM
Nostang 96z
Sep 15, 2002 10:15 PM
