clutch pedal assembly removal
Old Feb 12, 2004 | 04:31 PM
LWillmann's Avatar
Is it possible to remove the clutch pedal assembly from the vehicle without removing the steering column?
Old Feb 13, 2004 | 08:56 AM
LWillmann's Avatar
ttt
Old Feb 13, 2004 | 10:36 AM
Brent94Z's Avatar
Super Moderator
This would probably be better suited for the Drivetrain forum. Since you aren't getting any answers here, I'll move this over to that forum for ya.
Old Feb 13, 2004 | 05:45 PM
95wannabe's Avatar
probably not possible...not sure why you're removing it, but if you've gone this far... 1 bolt at the u-joint will disconnect column from shaft under the hood, 3 bolts will remove collar holding column to firewall, an just 2 more will drop column down from the dash, then you'll have 3 or 4 wire connectors to unplug
Old Feb 13, 2004 | 07:05 PM
961le's Avatar
yes. i did it ,you will leave with some battle wounds though. not too bad.
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
Rod Bender
May 16, 2015 02:16 PM
BPS
9
Mar 5, 2015 10:51 PM
eazyZ
Mar 1, 2015 07:12 AM
HectorM52
Jan 30, 2015 11:08 PM
