10 bolt and 12 bolt
Old Feb 15, 2004 | 10:30 PM
fstenuf's Avatar
10 bolt and 12 bolt
i was wondering what the difference between a 12 and 10 bolt besides the number of bolts on the pumpkin. cuz i have a moroso 12 bolt with a 33 spline. what does the 33 spline mean? thanks for the info
Old Feb 15, 2004 | 10:39 PM
A 10-bolt (at least the F-Body version) uses a 7.5/7.625" ring gear. A 12-bolt uses an 8.875" ring gear. Hence, its much stronger.
The axles are "splined" to the side gears in the carrier, or to the spool, and the number of splines relates to the strength of the axles/gears.
Old Feb 15, 2004 | 11:07 PM
fstenuf's Avatar
so is 33 strong?
Old Feb 15, 2004 | 11:09 PM
fstenuf's Avatar
i'm also runnin 430 gears...should i switch to 4:11's or is it not worth it?
Old Feb 15, 2004 | 11:39 PM
chpmnsws6's Avatar
33 spline is strong enough for anything you have
gearing depends on your car. you wanna be 200rpm past you peak power in 4th when you cross the finish line
Old Feb 15, 2004 | 11:48 PM
fstenuf's Avatar
thanks for the info
Victor Lamb
Aug 26, 2017 02:52 PM
BLK1997Z28
May 2, 2015 01:26 PM
maybe2fast
Mar 16, 2015 09:45 AM
DETROIT_AREA_00_SS
Aug 21, 2002 06:38 AM
