93 T56 clutch slave cylinder adapter fitting help?
Old Sep 8, 2010 | 07:53 PM
tylerwerrin's Avatar
Hi guys,
I need to swap out the old stock hydraulic fitting on my slave cylinder and put on an adapter fitting. Summit stocks them in both AN-3 and AN-4. I called up Russell Engineering (the manufacturers), and the guy said that either AN-3 or AN-4 will work for my application (just a stage 1 clutch, no performance mods).
I'm doing this because it is for a swap project I've been working on. Plus, i'm ditching the slave w/o the bleeder in place of a 92 camaro slave w/ a bleeder (same part, just has a bleeder on it...nice!)
I was wondering if anyone out there has done a similar thing, and should I go with the AN-3 or the AN-4. I don't know what adding an additional 1/16 OD to the line would do, but I just wanna make sure it'll be okay.
Any help would be greatly appreciated. The two summit part numbers are:
RUS-641001 (AN4)
RUS-640281 (AN3)
Tyler
Old Sep 10, 2010 | 12:24 AM
Colin's Avatar
Tyler,
There's a link on my forum at H-Body.org regarding this issue. It's an odd-sized fitting. Here's the link: http://forums.h-body.org/viewtopic.p...it=t56#p171076
To keep it simple, two members have accomplished what you're trying to do. Tim McCabe just put a T56 in his '72 Vega and this was his reply to my question about clutch hydraulics. He is using an S10 slave and master with custom lines.
The S10 uses a metric 12x1.5 thread from what I remember. No one makes a direct adaptor, so I had to go through 2 steps to get to the AN3.
The master and slave came out of a mid 80's S10, I don't remember the exact year.
It took a number of trys to get the master mounted just right, the rod is not a perfect straight push into the bore at the start of the stroke, but it is centered by the end of the pedal travel. I drilled the main hole for the bore, then rotated the housing until I had everything lined up, then drilled the 2 mounting bolt holes.
The slave was just mounted using an adaptor plate. Just hog out a bit of the extension housing to make room for the mounting bolts. I used the T56 activation rod for the slave, the thickness of the adaptor plate did not seem to be an issue.
HectorM52
Jul 30, 2017 11:46 AM
Briah.hood
Feb 17, 2015 02:10 PM
HectorM52
Jan 30, 2015 11:08 PM
Jason Short
Jan 19, 2015 06:34 PM
