Shifter Differences
Old May 28, 2010 | 09:54 PM
dirtybird81's Avatar
Shifter Differences
I can get a good deal on a c5 corvette shifter my question is will it fit on the t56 I have in my 96 z28 it is a hurst brand shifter and says it'll work on 93 thru 02 model c5 let me know so I don't pull the trigger on a part I can't use thanks in advance
Old May 29, 2010 | 12:12 AM
camaronutt's Avatar
I thought the Vette used a remote mount shifter....
Old May 29, 2010 | 07:37 AM
this is just the kind of feedback i need i know nothing about vettes much less the shifters in um i figured they were different thanks for confirming
Old May 29, 2010 | 09:28 AM
The Corvette T56 is only the guts of the standard "engine mount" trans used in the F-Bodys. On the C5 the guts are housed in a large assembly that bolts directly to the differential housing, hanging on the rear suspension crossmember. As a result, the shifter mounts above the torque tube that connects the rear of the engine to the front of the tranny, with a long rod that connects the shifter to the trans. The chances of the Corvette shifter bolt pattern being the same as the F-Body mount would seem very slim. If they were the same, aftermarket shifter manufacturers would not have two different model numbers.
This is the only photo I could find of a C5 T56, and its being installed in the back half of a Gen 1 F-Body. The shifter rod connects to the black dot right above the torque tube.
http://www.t56kit.com/company/50/50/chassis/WD31.jpg
ducttape1975
Classic Engine Tech
Mar 26, 2016 04:17 PM
JCSWS6
Jul 19, 2015 06:47 PM
Z28amustangklr
Jul 18, 2015 11:05 AM
ducttape1975
Jul 10, 2015 06:29 PM
