Pressure Plate Balance ?
Old May 31, 2010 | 02:08 PM
Max Lewis's Avatar
The pressure plate I bought from Kentucky Clutch (local shop) I noticed doesn't have the holes drilled in the weights to balance it. Like I have seen in other clutches I have used and installed for others. What would you do install or take it back and ask him whats up?
The pressure plate has 3 weights. Two of the weights have holes drilled in them on the old P.P. and no holes drilled on the new P.P. I have heard of people on here having vibration problems with these type P.P. The shop said they were Valeo P.P. I don't think they are.
New pressure plate weights
http://i789.photobucket.com/albums/y...g?t=1275332264
Old Pressure Plate Weights
Old Jan 2, 2011 | 05:44 PM
Ricardo's Avatar
Re: Pressure Plate Balance ?
I know this thread is old, but I would like to know what you ended up doing with your clutch kit.
Did you install it?
Did it vibrate at certain RPM?
I am looking for a bolt on clutch for my M6 car and would not like to have vibration issues. Is there one brand whose pressure plates are balanced?
Old Jan 2, 2011 | 11:47 PM
Procharged94Lt1's Avatar
A quality kit should be neutral balanced for you to begin with..there are multiple clutch recommendations depending on the end application.
BigWil
Mar 29, 2015 12:24 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Newgmman
Feb 25, 2015 02:53 PM
