Replace short block / engine in 95 z28
Old Jul 24, 2010 | 11:48 AM
Z28-50's Avatar
Found a 95 Z28 with rod knock for my Son.
Have a 72 350 out of a Camaro all rebuilt sitting in a Jeep.
Is the 72 engine compatible with the 95 Z?
Short block, long block, starter mount, heads, etc....
Old Jul 24, 2010 | 12:13 PM
bigjoebowski22's Avatar
Short answer.... no. Your best bet is to just find another LT1. Pretty much the only thing compatible is the rotating assembly.
Old Jul 25, 2010 | 09:21 AM
rskrause's Avatar
Moderator
You can put a Gen I small block in a 4th gen F-body w/o a big problem.
Old Jul 25, 2010 | 10:39 AM
You just have to recognize you can't use the 95's computer unless you have the cam position signal from the Optispark. Or you need to put the cam position optical module in the Gen 1 SBC distributor. If you are satisfied with a carb and conventional distributor, you don't need the computer.
Or you could get the manifold and injection/computer off a 3rd Gen MPFI engine.
11racing
Classic Engine Tech
Dec 26, 2014 05:40 PM
sskevinm
Dec 18, 2014 11:16 AM
Bearmans
Dec 3, 2014 05:28 AM
siguy
Nov 27, 2014 10:07 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
