th400 or 4l60e
Old May 23, 2010 | 04:47 PM
mark97ta's Avatar
th400 or 4l60e
I have a turbo set with close to a 1000 hp at the wheels with a t56... I want to switch to a auto but hate the idea of turning 3k at 55 mph, but i know the th400 will handle that kind of power, what are my options? can a 4l80e can used if it is manually shifted or will it have to have a stand alone tcm? Or can a 4l60e stand up to 1000 hp
Old May 23, 2010 | 08:10 PM
93v8clone's Avatar
a very close friend of mine has a t-t t/a with the same hp . he went thru 4 4l60e,s in his car . he is now usin a 4l80e in it . if your gonna go in and do the swap do it right man
Old May 24, 2010 | 06:19 AM
mark97ta's Avatar
10-4 thanks man, I didn't think a lt1 pcm would run a 4l80e, anyone else wanna chime in,,,
Old May 24, 2010 | 07:50 AM
Manual valve body TH400 with a Gear Vendors (0.78:1) overdrive helps. The GV will handle 1,000HP.
http://www.injuneer.com/images/photo.../DCP02954a.jpg
Old May 24, 2010 | 01:33 PM
byrons1502's Avatar
The gear vendors is a great idea. I would run the 4l80e. With either one it would be thousand times better than the 4l60e.
Old May 24, 2010 | 04:52 PM
mark97ta's Avatar
thanks for the help, the th400 seems to be the way to go looking at the price of a built 4l80e,
Old May 25, 2010 | 05:58 AM
AL SS590 M6's Avatar
Moderator
But....................if you don't want that 3000rpm at 55mph then you'll need overdrive. Which means 4l80e, 6l80e, or as Injuneer said a th400 + a GearVendors OD unit.
There is NO cheap reliable way to way to get 1000hp from the motor to the wheels and have OD too.
Old May 25, 2010 | 02:51 PM
If I had to pay full price for the GV, I wouldn't have bought it. I got it "slightly" used (by George Baxter in his 1,125HP 30th SS convertible) for about 1/2 original cost.
The GV also comes with a hefty weight penalty. I'd guess it weighs about 40-50#. I should have weighed it first. Will require a very short DS, and a custom DS loop. In my case, it eliminated the space for my previous Y-pipe, forcing me to run a new dual exhaust.
Old May 27, 2010 | 05:56 PM
mark97ta's Avatar
sweet! that was a great deal I'll keep an eye out... I still what it would it would take to run a 4l80e on a lt1... it might be too much trouble
Parts Wanted
May 1, 2016 10:25 AM
blac94Z
Nov 4, 2015 01:59 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
football4life
Oct 4, 2015 07:48 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
