Factory Rear end is leaking
Old Jul 9, 2010 | 11:38 PM
TheBlur's Avatar
So, how hard is it to replace a pinion seal ? I believe that's the right name for it, it's the one closest to the drive shaft. I want to do it myself so hopefully I won't need any special tools. I have access to a lift so that will help. Thanks
Old Jul 10, 2010 | 11:00 AM
Kevin Blown 95 TA's Avatar
There's been a lot of posts on this. See what you can pull up on a search.
It's not too hard to do but you need to make sure to retighten the pinion nut properly and you might want to seal your splines as well in case it's leaking through there.
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
Collector Car
Jan 5, 2015 10:58 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
