howling in rear end
Old Jun 7, 2010 | 07:57 AM
wildracer's Avatar
howling in rear end
im not too sure if this is where i should post this but .... i have a strange howling coming from the rear end it only happends as i am driving and i release the gas and then the howling starts but as soon as i give it some gas it stops.... any ideas??? i had a friend of mine tell me that GM has a rear end fluid that is made for this reason... is this true? any help would be great thanks
Old Jun 7, 2010 | 08:26 AM
jasonface's Avatar
That was the first symptom that mine was going bad. I think it's 'cause the teeth are wearing, increasing the clearances between the ring and pinion gears. The howling on coasting/decel goes away when you gas it, because it then forces the teeth into tight contact with each other.
Old Jun 7, 2010 | 09:30 AM
Z28SORR's Avatar
Year, make, model?? Is your differential leaking(pinion seal leaks are common)? Have you checked the fluid level?
Old Jun 7, 2010 | 10:06 AM
wildracer's Avatar
sorry about that its a 97 z28 30th yr fully stock. fluid level is perfect and there is no leaks around the pumpkin or any where elsea around the rear end..
Old Jun 7, 2010 | 02:05 PM
97FormulaWS-6's Avatar
Sounds like you've got a pinion bearing that's going out. That's the #1 symptom.
Old Jun 7, 2010 | 08:58 PM
96 Z 28's Avatar
Well I had the same problem, and replaced the fluid with Amsoil. Whining went away
I figured it was wear, but it's possible that the fluid is just thinned out from time and abuse
Worth changing the fluid vs. installing new parts
blac94Z
Mar 2, 2015 06:03 PM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
