Transmission help.
Old Sep 20, 2010 | 01:56 PM
ny94z28's Avatar
Transmission help.
Ok so i want to start be saying i have done lot or research on this and just dont know where to go with it.
The problem:
I have a 94 Camaro z28 Stock. It seems to be in "Limp Home Mode" I have 3rd gear when in Drive or Overdrive and 2nd with a manual shift. Thats it. I have pluged in the car to my laptop and checked for codes with the key in the on position i do not get any codes at all. Once car is turned on and running for about 30 -45 secs codes 84 "3-2 Control Solenoid Circuit Fault" pops up. This will stay on. Once i shift the car into gear i get codes 81 "2-3 Shift Solenoid Circuit Fault" and 82 "1-2 Shift Solenoid Circuit Fault". These are the only codes i am getting. What should my plan of action be from this point?
Old Sep 20, 2010 | 05:31 PM
brandons94lt1's Avatar
Hmmmm u know what's odd, when my 4l602 went out I didn't get any codes, and r u sure that u don't have 2nd and drive? With no tcc assisit? Cause that's what my car did when my trans took a dump. I had estimates on a rebuild and the price of a new tranny from chevrolet, none of em could touch art carr out of abelene tx I got a killer tranny througfh them, and my car had the performance shift button in it too, I told em what I had, what I was going to do and how much hp I was planning on putting down, and how I was going to do it. Shipping and all about 1200 maybe a little more. If u can find a tranny rebuild with corvette servos, a stall converter, with an anti ballooning plate, modified shift pressure and an aftermarket aluminum pan with bolts for install, u let me know, oh they didn't ev en charge me a core, so I made an extra 100$ by selling my junk case to a local tranny shop for their core stock. Yeah I coulda got more, but I was happy. And they even let me pay for the tranny over a 3 week period, it was xmas time and I spoil my kid lol.
Old Sep 20, 2010 | 05:37 PM
If your interested, send me a pm, I'll email u a copy of my receipt, and u can see what I paid, some of what I got.
Old Sep 20, 2010 | 05:51 PM
ny94z28's Avatar
I forgot to say that this trans was just rebuild and has been doing it since the rebuild.
Old Sep 22, 2010 | 10:07 PM
95TA04GOAT's Avatar
If this has been happening since the rebuild bring it back to the rebuilder. Usually when solenoid codes are set the solenoid is bad or there is a wiring fault.
Old Sep 22, 2010 | 10:51 PM
Nice bit of info to leave out lol, yeah that changes everything. Have you brought it back to the shop? How long has it been since the rebuild? I simply ask because a lot of shops will say it's unrelated or customer caused it after a few days, or weeks. The bad shops mind u, did u get a warranty? Either way I would bring it back to them, depending on the answers to the questions above u may have to get very serious with them, but if they're reputable and it hasn't been to long, or it's still under warranty u should be fine. That makes the question easy for us, not so easy for u
Old Sep 22, 2010 | 11:06 PM
Hey just another quick bit of info, code 82 is 1-2 shift solenoid circuitry is faulty, but it also can mean that there's no 3X reference pulses detected by the ecm/pcm. Just an fyi, doubt it helps here. Good luck with the shop.
Old Sep 23, 2010 | 05:17 AM
This doesn't belong on "LT1 Based Engine Tech". Lets move it to "Drivetrain" where it belongs.
Old Sep 23, 2010 | 09:59 AM
Sick97SS's Avatar
+1 Take it back to the shop and raise hell
Use the line "im gonna burn this ***** ****a to the ground" to let them know your serious...works every time.
Old Sep 23, 2010 | 07:30 PM
ny94z28's Avatar
Please close this post. Problem has been solved. It was a broken pin on the transmission plug. Thanks for all input and info with this issue. Sorry for posting in the wrong spot.
Old Sep 23, 2010 | 10:22 PM
We don't close threads when a problem has been solved.
Posting on the wrong forum is not unusal for newbies, and not really a problem. Its the members with 3,000 posts who refuse to post on the correct forum who are a problem.
marlar98
Sep 12, 2018 07:18 AM
DarksideII
Parts Wanted
Sep 23, 2015 11:14 PM
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
themex2002
Sep 2, 2015 03:47 PM
LazyLemming
Aug 29, 2015 07:36 PM
