A Head Scratcher (LS1 M6)
Z28 will NOT go into gear with the car started.
With the car off it will go into gear, and while I turn it over it will lurch forward while in first.
I've bled the clutch today, there was a little air in the system, but it didn't fix the problem
Problem just appeared after sitting in the driveway for a few weeks.
What things just sitting in the driveway could cause something like this though?
I mean sure a broken pressure plate could be the problem, always a possibility, but wouldn't a hydraulic issue be more in the realm of that possibility?
I've got a buddy that's coming over tomorrow to check the slave cylinder.
the pressure plate could have broken when you pushed the clutch in to start the car, or a seal could have deteriorated in the time it sat - its really hard to say from this position
try a search and take a look at some of the other causes and repairs to get a better idea of what you are dealing with
10-31-2016 11:09 AM
