trans fluid change when installin tq and shift kit
Old May 24, 2010 | 11:13 PM
z28beast's Avatar
ok so im going to have a shift kit installed into my trans and the only thing im worried about is the fact that my trans fluid was pretty brown and im changing the tq so it will be all brand new fluid when i fill the trans back up....ive heard that putting new fluid in an old trans will mess it up bad....is this true? also what is a good brand of transfluid to use when i have it reassembled?
Old May 25, 2010 | 10:12 AM
Pro Built Automatics's Avatar
Use a oem type of filter. It must have on it SP, SPX, filtran, or "microfelt" on the filter. Many auto parts carry them. A Duraprene pan gasket is the best to use, and torque it to 65-75 inch pounds. Do not use any gasket sealer. A good quality non-synthetic Dexron III fluid such as Mobil, AC Delco, Aamco (which is Mobil repacked) will work here. Flush the cooler and cooler lines. Drain the transmission as best possible. If you want to improve the TransGo Shift kit? Let me know?
Old May 25, 2010 | 11:25 AM
z28beast's Avatar
Originally Posted by Pro Built Automatics
Use a oem type of filter. It must have on it SP, SPX, filtran, or "microfelt" on the filter. Many auto parts carry them. A Duraprene pan gasket is the best to use, and torque it to 65-75 inch pounds. Do not use any gasket sealer. A good quality non-synthetic Dexron III fluid such as Mobil, AC Delco, Aamco (which is Mobil repacked) will work here. Flush the cooler and cooler lines. Drain the transmission as best possible. If you want to improve the TransGo Shift kit? Let me know? Dana
ok ill go with the mobile.......and yes its a transgo 4l60e-hd2 shift kit and im having it installed along with the aluminum ..?valve body seperater plate?
PCLZ28
Dec 24, 2015 05:19 PM
Jul 4, 2005 05:00 PM
Rich_z28
Sep 13, 2002 03:35 PM
Rich_z28
Sep 8, 2002 12:00 AM
Rich_z28
Aug 29, 2002 10:44 PM
