4L60E VSS Reluctor Ring Question
Old Jul 6, 2010 | 03:55 PM
jwindh1's Avatar
I have a '71 Nova that has been retro-fitted with a LT1/4L60E. When this was done, the vss was removed and a conversion to a mechanical set-up was done. I still have the tailhousing with the vss pick-up and I want to convert to autometer electronic gauges.
I have gotten the GM part number for the reluctor (GM#24202711) and spoken with speedometer solutions. It sounds like all that I need to do is put the vss pick-up back on the tailshaft housing, remove the drive gear for the mechanical setup from the output shaft, install a new reluctor wheel, and then wire it up. Am I understanding this right? What goes into installing the reluctor wheel, what is the procedure?
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
1963SS
Feb 6, 2015 10:05 AM
ChrisFrez
Feb 1, 2015 08:26 AM
Queens94z28
Dec 20, 2014 09:11 PM
